General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
CB Engine Interference?
Old Jul 17, 2007 | 12:00 PM
drock2's Avatar
I have a Uniden CB mounted on the center console, passenger side. The antenna is mounted on a bracket in the rear of the truck. Ever since I installed the CB it is very sensitive to engine noises. When the engine is running and especially when I'm driving, if the CB is on, you can hear the engine through the speaker. If the engine is off it works well. Has anyone else had this issue, do I just have to deal with it or is there some way to fix it?
Thanks
Old Jul 17, 2007 | 12:47 PM
4Crawler's Avatar
Yep, common problem on the more inexpensive CBs. A few things to try:
Make sure the antenna is well grounded.
Run a dedicated power and ground wire for the CB, I run mine from the battery back (fused) and twist the wires together for better noise isolation.
Add an ignition noise filter right at the radio.
I do all 3 and get almost no noise in my Cobra 75.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
