Brake lights not working
my brake lights are not working, i have checked every fuse on the truck and thier all fine, i have changed all the bulbs too. all lights work except brake lights. the brake switch is good.they work one day then the next day they dont. any help would be greatly appreciated.
any luck on finding the problem? I'm having the same issue, i can turn on the lights and everything works but apply pressure to the brakes nothing, changed the fuses, lights, switch still nothing, everything looks good, but not working.
the fuse that powers this is a 15A labeled "STOP". if this has power at both ends of the fuse check at the bulb for dirty connections or sockets, also i have seen intermittent problems with the brake switch. does yours have cruise?
yeah it's got CC, i ended up replacing all the fuses and cleaned the connectors, also changed the switch, and now everything works great...i saw some corrosion on the fuses i'm guessing that was the issue.
Aleeex_u
06-05-2016 06:52 PM
