YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-22-2008, 06:41 PM   #1 (permalink)
Big 3 wire upgrade and fusible link
I have a new battery I need to get in my taco. The problem is that the posts are a little further away than the current wire to my fuse box will allow. So I need to run some new wire that's a little longer.
While surfing, I came across a ton of links about the "big 3" upgrade and now seems to be as good a time to do that as any. So I need to find a source for 4 ga bulk wire and connectors. I've read some places that welding cable is ok to use as well.
Another question I have is what kind of wire to use for the Battery + to fuse box. I've come across some info about fusible links that seems to indicate that there is special wire that's designed to melt under too much load. I haven't been able to find a source with this wire in any of the larger gage (currently have 10 ga). I have found bulk 'primary wire' that's 10ga and 1 place that has 12 ga "fusible link primary wire". But I can't find 10 ga. fusible link anywhere. I'm assuming that since I have 10 ga in place now, I should stick with it and not try using 12 ga.
Can anybody enlighten me?
__________________
DD - 02 ext-cab Taco, SAW/AAL lift, Armor a la budbuilt, bentup and badlands, manual hub conversion, 265/75-16 TKO's
Project - 85 ext-cab lawn ornament
mrdoug is online now
Sponsored Links
To remove this ad, register today!
Old 07-22-2008, 06:50 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
if you just need to add a few inchs go down to your local car audio place pick up a inline amp fuse and some 4ga wire cut then end off the stock terminal strip the wire place in the fuse holder then run a new wire at the other end to the battery
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 07-22-2008, 08:00 PM   #3 (permalink)
Thanks for the tip!
I just came across this post that has a possible solution as well:
http://www.yotatech.com/f131/sears-d.../#post50854649
I should have searched a little more before posting.
__________________
Old 07-22-2008, 08:08 PM   #4 (permalink)
muddpigg's Avatar
I just used the fusible link that is already protecting the vehicles electronics. I ran 1/O welding cable. I didn't want anything smaller than my winch cables in the charging curcuit (the tech articles I saw used a two curcuit explanation for the vehicle electronics). I left the charging curcuit unprotected as the winch will draw more than any fuse I found.
Worth while upgrade IMHO. Good luck.
muddpigg is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Replacing Fusible Link Gadgtgal 86-95 Trucks & 4Runners 4 08-31-2007 08:13 PM
BIG 3 wire upgrade? doc76239 General Electrical & Lighting Related Topics 41 03-10-2007 02:13 PM
Help removing 80 amp fusible link mojotoy 95.5-2004 Tacomas & 96-2002 4Runners 3 10-18-2004 12:57 PM
How do I change the fusible link on the eng. compt. halza 95.5-2004 Tacomas & 96-2002 4Runners 4 02-19-2004 04:47 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
