Aftermarket alarm kill switch problem, reset ECU? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-01-2009, 08:00 PM   #1 (permalink)
Let me preface by saying this is not an OEM factory keyless entry, but a compustar (I don't know which model it is, and I can't tell from the remote).
I accidently let my battery die one day and found out that the car had a killswitch on it, so even when I charged the battery, the car still wouldn't start. I pulled the fuse for the alarm, however when I plug the fuse back in, the killswitch is still activated.
If I unplug the battery, with the alarm fuse plugged in, will this rid me of this problem? Thanks for any help!
mtpktz. is offline
Old 11-12-2009, 04:43 PM   #2 (permalink)
Bump.
mtpktz. is offline
Old 11-12-2009, 04:56 PM   #3 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
There is no way to "reset" the alarm by simply unplugging. However, there is a way to disable it. That would be covered in the alarm owners manual. Assumably you no longer have that so you would have to go online and search around to find the way to bypass it. I had an alarm in my old 4Runner and the control box went tits up, so I had to bypass it. Usually they have a small button or switch to depress while turning the ignition to accessory or something. Every alarm is different.
Or, just yard that worthless junk out of there. Those kill switch alarms are problematic and not worth the time to mess with them.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 11-13-2009, 12:43 AM   #4 (permalink)
Well, the alarm is currently disabled because I pulled the fuse so pulling it out really won't help anything because all I want is my keyless entry to work again.
Thanks for the response.
mtpktz. is offline
Old 11-13-2009, 08:06 AM   #5 (permalink)
Staff
Again, pulling the fuse does NOT fix it. In fact, it merely makes your truck completely disabled. When those alarms are installed, they rely on a start circuit interrupt, usually by cutting the ignition switch wire and splicing in the alarm/ignition interrupt.
Either yard the system out, or get the owners manual for the system and figure out how to reprogram or disable it.
__________________
Tags
aftermarket, alarm, bypass, car, disabling, kill, reset, switch, switches, system, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
