General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
96 Tacoma No Charge. HELP!!
Old 04-27-2013, 05:21 PM
Carterperformance's Avatar
I have a 96 4x4 tacoma, i put a new altenator on it.. still not charging the battery.. jump it off and it'll run for a few until the battery dies then it'll start skipping and eventually die. Do these altenators have a internal or external voltage regulator?? They told me at advance that it was internally regulated.. but i beg to differ based on all the factory wires that hook to the altenator. If externally regulated, where is the regulator.. Any help would be greatly appreciated.. thnks
Old 04-28-2013, 12:18 AM
wyoming9's Avatar
Red face
I think the last Toyota i saw with a external regulator was back on a 83 22R but i could be wrong.
So yes it has a internal regulator .
If it has the stock engine.
Being it is a Toyota it very well might have a engine from the 1960`s .
If this is a new alternator just take it back and get another one.
If it tests good then something on the truck is causing the no charge issue.
Old 04-28-2013, 06:15 AM
rworegon's Avatar
Check wiring for corrosion and for a popped fuse both in the engine compartment and the under-the-dash boxes.
Do you have a CEL on?
Old 04-29-2013, 09:33 AM
Ive checked all i know to, and everything you guys have recommended.. Still having problems. How about the starter? it works fine but could there be a short internally thats drawing power??
Old 04-30-2013, 01:46 PM
wyoming9's Avatar
Red face
Check that your ground cables are good .
Belt tensioned as it should be.
Time to buy a Multimeter.
To get some real numbers.
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
irv
09-29-2015 01:04 PM
charlie_fong
09-27-2015 10:06 PM
Project90
09-24-2015 11:40 PM
Quick Reply: 96 Tacoma No Charge. HELP!!
