2000 tacoma running on 3 cylinders?
My perfectly great 2.7 tacoma started cutting out and ruuning rough. the check engine light would start flashing and then go off. it ran ok for just a little while, then started doing it again. I thought it would be one of the coils, but my mechanic says they are ok? He replaced a couple of spark plugs but tells me its still running bad. Compression checked out ok. anyone got any ideas??
After further checking it was a plug wire issue. One of the long plastic boots that attatches to the plug had a crack and was firing sporadically/horizontally to the block. Thanks for your help.
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
