General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1998 factory CD player skipping
Old 07-02-2006, 05:44 PM
Steve 1stgen's Avatar
Hi Everyone,
I have a 1998 Toyota 4Runner limited with a Factory Radio, CD, tapedeck. The CD player is skipping on the smallest bumps. Any ideas on how to fix outside of getting a new radio? Thanks.
Steve
Old 07-02-2006, 10:16 PM
^VooDoo^'s Avatar
You dont fix it, You replace it, The CD player anti shock works great when its new but after a few years and weathering the rubber shocks inside sag causing the disk to hit the insersionplate, If they foamfilled them it may have lasted alot longer.
I have pulled 2 apart and both had the same problem and you cant re-inforce them because the ride will be to rough and make it skip anyways.
Old 07-03-2006, 04:58 AM
Marc P's Avatar
What years of radios are interchangeable? My cd player on comes out of the left side speakers now...the radio works fine. I think it is from too much wheeling.
Old 07-03-2006, 02:31 PM
^VooDoo^'s Avatar
Alot are interchangable, I even had a am/fm casset, EQ, From my 85 celica but really needed a CD player so bought a POS Sony, TIme for something new now.
Old 07-03-2006, 07:23 PM
Elton's Avatar
i like haveing a real cd player
Old 09-23-2007, 07:33 AM
tns1's Avatar
My 98 ltd CD also skips if the road is the least bit rough. The stock radio is fine for me, but I do want both CD and cassette. I see there are lots of used stock radios for sale. I figure the newer years would be better + maybe have more features like aux in or MP3 play. Any idea what years would slip right in and use the same connectors?
Also does my radio have the 12pin changer plug? This seems to be the common way to add aux in.
Old 09-23-2007, 07:37 AM
OSU4Runner's Avatar
x2...Go pick up a nice aftermarket CD player!
Old 09-23-2007, 08:33 AM
Fossilized
Staff
dropzone's Avatar
IPOD, no skipping
Old 09-23-2007, 10:34 AM
nick-m's Avatar
I just did this, swapped out my '96 cassette deck for a double DIN unit. On the front of your radio, what model number does it say?
Old 09-23-2007, 01:35 PM
tns1's Avatar
My model is 56808. It is the tall unit (double din?) with CD, Cass, Radio. Since I got a new set of tires, the CD does not skip as bad. I have had it out before when I was looking to see if I could fix the CD myself, but from the other posts I believe I'd have to replace the CD module. Seems simpler to just replace the entire radio. I'd rather have a stock looking unit since they don't get stolen. I don't have the external CD changer, and if the radio supports it, I would use an MP3 player and an aux in instead.
Old 10-16-2007, 10:35 AM
tns1's Avatar
DIY skip fix
https://www.yotatech.com/forums/f131...8-4rnr-127128/
18
09-21-2015 06:15 PM
Ilovemountains
09-15-2015 04:17 AM
zz_denis
09-06-2015 03:43 PM
--Oz--
09-06-2015 01:06 AM
kelly1450
09-02-2015 12:29 PM
Quick Reply: 1998 factory CD player skipping
