| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Commando question
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q Last edited by Praufet; 03-02-2006 at 01:49 AM. |
#2 (permalink) |
Sponsoring Member
Are you getting a voltage pulse at the unlock wire when you hit the button? Did you re-learn the remote to the brain? Does it lock but not unlock? Does it start?
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#3 (permalink) | |
Quote:
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#4 (permalink) |
Sponsoring Member
Ahh true - whoops.
Then check for a "pulse" of continuity (yeah, that's what I meant! ) between the trigger wire and ground.Oh hey... did you remember to ground the safety interlock, and are you running a hood switch? I can't get to my install manual, but I remember that there's a specific wire that had to be grounded if you weren't using it. I think it was for a cutoff? And then the hood switch was a separate "oh yeah!" moment when I installed mine.
__________________
#5 (permalink) |
hmm, I'll look at the diagram and check to see if I can find the wire you're talking about.
__________________
#6 (permalink) |
Sponsoring Member
Hey Brian;
I found the manual online - we're talking about the FM-870, right? http://www.commandocaralarms.com/man...870install.pdf Anyway... the wires I'd start looking at would be: H5/1 - White/Black, Negative safety shutdown H5/2 - White/Violet, Positive safety shutdown H5/3 - Black/White, Remote start enable (this is the one I was thinking about above) H6 - This is the door look trigger You may also want to reset the alarm options back to factory. This is on Page 22, "Return to factory default setting". That would clear up any chance that it's in some weird "safety" mode.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Commando 870 | chadbobb | Alarm Systems | 2 | 01-24-2007 12:59 PM |
| Those of you with Commando 870 | chadbobb | Alarm Systems | 5 | 11-23-2006 11:19 PM |
| Commando 870, so far, not so good | MatthewP | Alarm Systems | 23 | 07-28-2006 01:18 PM |
| Question about Car Alarms (Esp. Commando 870) | paranoidandroid | Alarm Systems | 2 | 03-24-2005 11:07 PM |
| Commando Car Alarms | Churnd | Alarm Systems | 0 | 04-14-2003 11:49 AM |
