wiring IPF fogs for 4ht gen ARB bumper
Old 09-22-2007, 08:16 AM
flyAddict's Avatar
I've searched and couldn't find anything specific to this topic.
Has anyone wired the IPF driving lights <edit from fogs> for the 4th gen ARB Bumper?
They come with a wiring loom and "special, exclusive to ARB relay". I've got OE driving lights, so I would think I could tap right into the existing wiring, which has a fuse and relay in the circuit. At the same time the instructions indicate you have to use there "special" relay with these IPF driving lights. Sounds like the old "OE parts will ensure your toyota runs at top quality for the life of your vehicle" bs line.
Thoughts??
Last edited by flyAddict; 09-25-2007 at 05:33 AM. Reason: correct fog to driving lights
Old 09-22-2007, 08:53 AM
Co-Founder/Administrator
Staff
Corey's Avatar
It is the exact same setup I bet as I have.
Right down to the Tacoma switch.
I have the IPF fogs in the ARB bumper, and the relay kit from ARB/IPF.
I used this diagram to wire mine.
http://www.pnw4runners.com/fj/ipf_fogs/ipf.jpg
You can also use this Hella diagram which I went by.
You will need the switch and 4 green wires when you can get get from members strap22 and trdpartsd4u.
They know the setup you will need to get.
I did not use the supplied IPF switch, the Toyota one is far better.
Here is the kit you will need from them.
http://www.shop.fjcruiseroffroad.com...&productId=135
Old 09-22-2007, 10:48 AM
flyAddict's Avatar
Thank you. i'm kinda bummed i can't use the steering column switch anymore for them... maybe i could use that to control the driving lights I'll hook up when I find them.
I just have a hard time believing the relay is all that special, since they are not exactly complex pieces of electrical engineering.
Old 09-22-2007, 11:13 AM
Staff
Corey's Avatar
I do not know all that much about relays, but I really thought the IPF kit was nice.
I am going to pick up the exact same loom kit from ARB locally.
I already have an extra switch and the 4 green wires, I will use it to hookup some future lights on the bumper.
Old 09-22-2007, 03:30 PM
KZN185W's Avatar
will that switch fit into the slots for a 3rd gen?
thank you
Old 09-22-2007, 04:04 PM
Staff
Corey's Avatar
Not sure Roy, you would have to PM one of the above guy's from where I bought it.
Old 09-23-2007, 06:02 PM
flyAddict's Avatar
As an update: the answer is yes, on a 4th Gen Runner you can hook the IPF driving lights directly to the old wiring. They will work just like the factory ones did. (yeah i should have known that one without asking.)
On the other hand, using the wiring loom that comes with them allows you the advantage of having them come on when you use your running lights (check the fog light setup instructions.) Which I'll probably do this eventually (once i get my hands on the switch Corey pointed me to) and then use the OEM wiring steering column switch for the Hella 4000 compact driving lights I have. That way it's easy off when there's another car coming.
Cheers, it's been a long weekend.
Old 09-28-2007, 05:43 AM
Staff
Corey's Avatar
Marshall, that is the way I wired mine, to the running lights.
That way they will not be left on accidentally.
Looking forward to using them here soon, have not had much of a chance, but with fall/winter coming, I smell fog coming soon.
Old 09-28-2007, 08:07 AM
flyAddict's Avatar
Thumbs up
I just found Bob's post for a 3rd gen OEM fog light rewire in the fuse box to allow them to operate with the marker lights. (link) it should be pretty easy to do on my 4th gen. sweet!
Old 09-28-2007, 08:16 AM
Staff
Corey's Avatar
That is actually by:
Factory Fog Lamp Re-Wire Mod
By Jalaber
bob just put it up in there when the old tech section that was in HTML format got moved into a forum format which is easier to edit.
Old 10-03-2007, 11:49 AM
flyAddict's Avatar
I had to modify the mod a little for my 4th gen SR5 (w/o daytime running lights) mainly it was the opposite prong on the relay that needed to be bent. and I had to run the wire out of the box and tap into the green wire on the side of the marker light wiring harness. But it works great.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
lledwod
08-30-2016 01:03 PM
nick9455649
09-11-2015 05:10 PM
A2theK
07-12-2015 10:46 AM
Quick Reply: wiring IPF fogs for 4ht gen ARB bumper
