Old 03-23-2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old 03-30-2015, 06:02 PM
  #1141
Fossilized
Staff
dropzone's Avatar
Two tool bags at Ace Hardware for $9.99
Using big one for recovery gear and small one for the spill kit
Old 03-30-2015, 07:14 PM
  #1142
rattlewagon's Avatar
Ohh Thats a good deal. I may have to find my way into an ace tomorrow.
Old 03-30-2015, 08:06 PM
  #1143
AR_yotaing's Avatar
Great ideas to try out
Old 04-10-2015, 12:20 AM
  #1144
Fossilized
Staff
dropzone's Avatar
One thing I found was that my pedals were a little slick, kind of would like an automatic transmission some day.
so I found some scrap diamond plate, in about 30 minutes:
I had these made:
cost was Zippo$$ and about 30 minutes
Old 04-11-2015, 09:13 AM
  #1145
Buck87's Avatar
Sweet! And I thought the moderators were just a bunch of pretty faces.
Old 04-13-2015, 08:57 AM
  #1146
v_man's Avatar
reinforced gas tank skid plate
I reinforced and stiffened up my gas tank skid plate with some #3 rebar ...
then I made some some L brackets and mounted it to the frame ... (truck is heavily modified so skid plate no longer lined up with old mounting hardware)
...about $14 in rebar , $6 in primer, and I feel much more confident that my skid plate can take a good hit.
Old 09-02-2015, 07:56 PM
  #1147
Jolene's Avatar
Hidden ipod mount - cup holder slot.
Music and GPS via my old phone. Always connected to charger and aux but still easily hidden from theives.
Old 09-03-2015, 04:57 AM
  #1148
irab88's Avatar
damn, that's slick. i might steal that idea.
Old 11-11-2015, 09:59 AM
  #1149
kbpickens's Avatar
Jolene, you might look into a 90 degree connector so the aux stays connected, but that's a fantastic setup.
My ultra-cheap mod is a light reminder (I kept draining my battery ). Get any cheap, loud 12v noise maker and wire it between the TAIL and IGN fuses (if your noise maker is dioded, wiring it one way will remind you to turn them on, the other, to turn them off; if it's not dioded, it will remind you to do both).
  • 3pk fuse taps - US$9
  • 2pk beeper/flasher - US$8
  • 25' black/red wire - US$5
Counting the cost of the parts I used, not the parts I bought:
  • 2 fuse taps - US$6
  • 1 beeper/flasher - US$4
  • 2' black/red wire - US$0.40
Old 03-25-2016, 04:16 AM
  #1150
Donk85's Avatar
Originally Posted by TC4RNR
My cheapo modo: found a piece of 2 gauge wire by the dumpster about 2 feet long, crimpped up between the battery "-" and engine block. that smoothed out the idle right there.
Did you have some ground issues?
Old 04-02-2016, 07:46 AM
  #1151
100hpbeast's Avatar
Some people may not like carpet in their rig but this is a flip for me so I decided to do Home Depot carpet like I have in the past. 18 bucks and some 3M spray adhesive, little bit of measuring and some patience and it will look pretty damn good.
Had to cut out a section to go around the center bottom dash support, should have left a flap of carpet to go completely around it. Planning and measuring and really thinking about how you want to lay the carpet down makes life a lot easier
All in all I'm happy with the result and if you guys need any more info on the carpet I have the part number and exact prices and can show you the 3M spray. Let me know what y'all think.
Old 04-04-2016, 01:58 PM
  #1152
Yota's Avatar
looks good! hows the floor pan though?
Old 04-04-2016, 09:22 PM
  #1153
100hpbeast's Avatar
Floor pan is in great shape, truck has zero rust on it, no dents and had the original paint on the floor pan that I just washed and dried before laying everything down.
Old 04-12-2016, 03:34 PM
  #1154
thedrewski86's Avatar
Lower seat/remove slider mechanism
I barely fit into my recently acquired '83 standard cab so I decided to remove the bench slider in an attempt to move the seat down and back.
First I pulled the seat (four bolts). The slider is held in place by four bolts (12mm I believe). I grabbed some cheap steel from the hardware store to make new brackets with. Here is the back bracket utilizing the stock bolt that held the slider on:
Here is how I did the front:
Pound the front one down and attach with the stock bolt/nut to the floor pan:
I just zipped a sheet metal screw in for the back one:
Repeat on the other side.
The seat sits awesome now and I have tons of room. I gained a ton of headroom, I have a nice reach to the wheel and it feels way more solid than before.
Old 04-12-2016, 04:50 PM
  #1155
Robert m's Avatar
Not worried about what happens to those thin sheet metal brackets if you get in an accident?
Old 04-13-2016, 12:46 PM
  #1156
Not really. The seatbelts are still bolted to the floorpan. Not to mention the seat is in stronger than the old rattly slider mechanism was holding it so if anything this is an improvement.
Old 04-19-2016, 07:59 AM
  #1157
Evan Tucker's Avatar
I think I am going to do the eye hooks in the panel it would be good for strapping things down.
Old 01-23-2017, 08:14 PM
  #1158
Fox_88Runner's Avatar
Bump!
Old 02-08-2017, 02:28 AM
  #1159
Staff
Terrys87's Avatar
For a broken antenna here is how I go about fixing mine.
Originally Posted by Terrys87
Another common problem with these trucks is the broken antenna.
How I fix the broken antenna. I use a 14mm bolt or similar size and thread it into the broken pvc tube.
Then I cut the head off.
Then thread the other piece back into the threaded piece. I have never had one to fail after I have done this repair. I see numerous trucks with antennas tilted back and it is from the pvc being broke.
Old 02-17-2017, 11:49 AM
  #1160
maxscott's Avatar
Brush guard
got some aluminum plate from Amazon it got hole punched through - it lite and keep the brush out of belts
Quick Reply: Show us your best cheap mods!
