the rustedyota rebuild
ok so i picked up a 86 yota a little while ago and it has frame rot so i figure easy fix so its been sitting for a little while now and i found a complete 93 yota rolling chassis with 8 inch suspension solid axel, springs in front, custom springs and blocks in rear. Heavy duty shackles all around. it also has a two inch body lift. the cab is a little beat up. also have a custom tube bent bumper for winch mount. It has braided brake lines too.Comes with stock tranny and an engine wiring harness so ima take the engine out of the 86 and put it in the 93 they both r 22re's then that fixes my problem with not wanting to do a sas and be amonster on tha street will update with pics soon
Dale Johnston
11
10-31-2015 10:22 PM
