Running AMSOIL
Running AMSOIL
Hey, does anybody here run AMSOIL in their Toy? If so I'd like to know about it.
I have a really good friend that runs AMSOIL in every sqare inch (that needs it, anyway) of his Nissan Frontier 4WD trucks, and he has a great experience with it. 275-300k miles and they all run virtually like new when he sells 'em.
Any comments, thoughts, or personal experiences much appreciated.
I'm considering running it in everything in my '93 (crankcase, gearbox, front/rear diffs, and t-case. Pretty much everything except for the obvious bits, like brake and clutch systems.
Thanks,
Bunta
Thanks,
Bunta
Thanks,
Bunta
Thanks,
Bunta
I have it in my diffs, and t-case. I did have it in my transmission, but it made my shifting not so good. So, I had to replace it with Redline MT-90-just the transmission. It seems to be a common issue with the manuals.
I run Redline.
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
For ALL things oil, check out www.bobistheoilguy.com
1 Post
Guys who have problems with shifting with Amsoil are running the wrong Amsoil gear lube! I put GL4 75w90 Amsoil Manual Transmission and Transaxle fluid in my manual transmission and it shifts great. My transfer case/front & rear diffs I run Amsoil GL5 75w90 Long life gear lube and it works great too.
I just switched my oil over from Mobil 1 10w30 to Amsoil 10w30, after having run the Mobil 1 10w30 for about 35,000 miles since I picked up the truck (I do have to admit I agree with the above, Mobil 1 is much more readily available and conveniently packaged), and I'm thinkiing I might keep using Amsoil Oil on top of having already put it in all my diffs/transfercase/transmission.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
