Ring and pinion help? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-20-2007, 04:26 PM   #1 (permalink)
b82ta3's Avatar
Ok so I am putting some 4.88 gears in my 84 pickup, this is the pattern I have come up with on the rear and well on the drive side I think that the first and 4th tooth of the paint look pretty good, but the center 2 look a little bit different than the other ones. My question is, How does this look for a pattern? should it be set a bit deeper? The coast side picture almost looks too deep, but those center two on the drive side look a bit shallow? I dont know I'm kinda confusing my self I think so I'm just going to stop typing now. Haha oh btw I just put the stock shim back in as a starting point.
b82ta3 is offline
Old 06-20-2007, 05:26 PM   #2 (permalink)
MudHippy's Avatar
You think you can do better than that, huh? How many tries did that take anyway?
If it were mine, I think I'd be plenty happy with those results. But, perhaps, the ever slightest bit deeper would be "perfect".
That shim might work fine. Looks maybe too thick, though. Yeah, on second thought try one the next size skinnier. Trying to move the contact patch back a bit towards the heel and deeper. Looks too much toward the the toe end. You know what I'm sayin' there?
Yeah, try the shim. Sorry I had to think that one through. It's been a little while since I fussed with my gears.
__________________
Sonoran Steel Early IFS Truss
Your IFS is SPINELESS without it
SonoranSteel.com
I'm Cuckoo For YOTA Trucks!
MudHippy is offline
Old 06-20-2007, 08:05 PM   #3 (permalink)
b82ta3's Avatar
alright i will do that here in the next couple days, any suggestions as to about how much shim to add?
b82ta3 is offline
Old 06-20-2007, 09:54 PM   #4 (permalink)
MudHippy's Avatar
Not thicker, skinnier, I wanna say like .002-.003 less than that one.
That will put the pattern deeper and towards the heel end. Not too much, I hope.
Where's ZUK(http://gearinstalls.com/)when we need him? He's got all the experience setting gears up. Could probably tell you exactly how much less shim you'd need.
Oh well, you'll have to settle for the advice of another novice for now. Sorry, I can't reassure you any more than that.
Good luck.
__________________
SonoranSteel.com
MudHippy is offline
Old 06-20-2007, 10:03 PM   #5 (permalink)
reggie 00's Avatar
Send a message via AIM to reggie 00 Send a message via Yahoo to reggie 00
Quote:
Originally Posted by MudHippy View Post
Not thicker, skinnier, I wanna say like .002-.003 less.
Good luck.
That guy has some amazing write ups.
and for the record i think you are doing a good job helping out. (not that i know if your right) the best times working on cars have always been just banging heads with my buddies figuring it out.
__________________
'83 Truck 4x4 - 4" lift, downey header,, lots of stickers.
'90 Runner $600 project ,32's on black Steelies,Optima Red Top, 1.5" Balljoint Spacers, 80 series Coils, Sleeping/Storage Platform extravaganza
You know enough to be dangerous, get out the way before you break something i can't fix- Pops
Bah, you are such a moose...
Rota est Fun!
Quote:
Originally Posted by ChickenLover View Post
Just get a bowl full of it, and dip 'em in.
http://www.4x4support.com
reggie 00 is offline
Old 06-20-2007, 10:05 PM   #6 (permalink)
big_blue_goat's Avatar
the girls I go with...
That's good enough for the girls I go with. There's no reason to be unsatisfied with that. Drop two thouy out on the shims and your good to go.
big_blue_goat is offline
Old 06-20-2007, 10:42 PM   #7 (permalink)
MudHippy's Avatar
I was partly wrong, did some more reading. Less shim will move the contact patch towards the heel end and shallower. Not DEEPER, oops. So, maybe that ain't the way to go.
Maybe that is about as good as your gonna get where it's at now. I hope so at this point. Then I can say, "see I knew it looked pretty good to begin with".
__________________
SonoranSteel.com
MudHippy is offline
Old 06-21-2007, 04:05 AM   #8 (permalink)
GSGALLANT's Avatar
Good save, Mudhippy. I was about to correct your post above, but read on to see that you corrected it yourself.
Anyways, I wouldn't touch it. The pattern is excellent.
A few other points... Did you get your backlash in spec? Did you get some good preload on your carrier bearings (adjusters torqued to 125-150 ft lb)? Did you install a solid pinion collar or a new crush sleeve? Either way, did you set your pinion preload correctly? Other than that... I'd say your good to go.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 07-02-2007, 08:17 PM   #9 (permalink)
b82ta3's Avatar
update
ok so all is set up and installed and i have been working at breaking them in. My question is, how hot should the differential be getting? I drive it for about 5 miles and it gets hot enough that when i hold my hand on it for a few seconds it feels pretty hot. I looked at the break in instructions on gearinstalls.com but i'm unsure as to how hot "Hot to the touch" so i was just wondering how hot i can go/should go to prevent damage to the gears. oh and i have about 70 ish miles on them as of now.
thanks
Adam
__________________
1984 Pickup. 4.88 gears, 33x12.5 inch SSR's chevy's out back, 3 inch Superlift springs up front, homemade tube box, and way too much other small stuff to bother listing.
b82ta3 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Ring and Pinion...Is more better? Denk Offroad Tech 5 10-21-2004 04:14 PM
ring and pinion and other questions outdoorfever 95.5-2004 Tacomas & 96-2002 4Runners 9 08-11-2004 07:44 PM
How much for a Ring and Pinion swap?? williemon 95.5-2004 Tacomas & 96-2002 4Runners 7 08-02-2004 08:21 PM
ring and pinion toy4fun 95.5-2004 Tacomas & 96-2002 4Runners 15 10-09-2003 01:34 PM
2009 InternetBrands, Inc.
