Rear end Binding and clunking!!!
Old 04-27-2007, 04:51 PM
deserttoy84's Avatar
Alright lately ive been having thing grinding tpye noice which today i found out its my rear diff. When i jack up the rear and spin the flange(no driveshaft connected) it binds and release every like 1/4 turn and makes an awful clunking sound. I planned on rebuilding both axles with lockers and new gears this summer but what do u guys think probably broke or is about to break inside?? only thing ive done was re tighten my flange nut and u joint which abovisly isnt my problem
Old 04-27-2007, 05:19 PM
Ringmaster's Avatar
It's time to pull the 3rd out and have a look. Sounds like massive carnage inside.
Old 04-27-2007, 05:52 PM
the guy i know who knows diffs inside and out said i prob bent the pinion gear. Looks like im re gear a loy soon then i though. FUN STUFF
Old 04-27-2007, 06:16 PM
MudHippy's Avatar
Hopefully just the ring & pinion, or just the side gears, not both. Good luck, and don't try driving it anymore till it's fixed, Dangerous. Whole thing will disintegrate at the worst possible time, says Murphy. Bent pinion? I'd like to see that. MOST likely missing teeth. Lots of personal experience with such, here.
Old 04-27-2007, 06:18 PM
881stGenRunner's Avatar
drain the the fluid and see if you have any metal stuck to the drain plug.
Old 04-27-2007, 07:22 PM
He said it was a possibility.He said if the pinion isnt moving around, which it isnt... then some teeth are gone so it looks like my teeth have decided to meet the tooth fairy.. But it sounds like some gears are gone. It seemed to start when i rotated my tires which would have nothing to do with my diff, prob just a quincidence. I plan on pullin git apart this weekend or next week and having it done. im just gonna re gear the rear end for now with 4:88 and lockers(wont use 4x4 since front end will be 4;10) Any website you guys recommend for some heavy duty ring and pinion sets??
Old 04-27-2007, 07:35 PM
drew303's Avatar
trailgear, marlin, randys ring and pinion, inchworm
places for gears.
Take pictures of what you find in there =)
Old 04-27-2007, 08:16 PM
MudHippy's Avatar
So far I've replaced all mine with stock gears from junker axles. I will probably order some from these guys if I ever do go for some after-market. Richmond has a pretty good rep.
http://www.peytonperformance.com/cat...+-+Toyota.html
Old 05-13-2007, 03:48 PM
I finally got it out, The housing of the open diff assembly was hitting the end of the pinion shaft and it made some pretty nice marks in it. I havent pull the 3rd apart but its something to do with the pinion shaft. probably bent or bad bearings.
the1998sr5
15
07-14-2020 08:35 PM
Daneums
08-20-2015 05:36 AM
rondogracing
07-14-2015 07:00 PM
hangtown88toy
07-10-2015 02:33 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: Rear end Binding and clunking!!!
