View Poll Results: Drop or lift?
Drop
10
55.56%
Lift
44.44%
Voters: 18. You may not vote on this poll
Panhard bracket: drop or lift?
Which is generally viewed as better dropping the bracket or lifting it. I'm looking at getting so lc rear coils so this would probably be needed.
Originally Posted by EWAYota
what is the panhard bracket? anyone have a pic of it?
Originally Posted by Praufet
I need one for the second gen though.
"angle".. heh. I crank me up.
The only 2 places that offer a 2nd Gen drop bracket are Downey and ProComp.
Downey has a 3" and ProComp has a 4". The Downey one is included in a kit that is around $150. The ProComp I'm told is $36.00, but 4", too long.
What I think you "could" do is drill a hole at 2.5" or 3" on the ProComp bracket.
We could also make you a drop bar, but that is $142.00 plus you ship us your bar for the work sonce we don't have 2nd gen cores.
Originally Posted by 914runner
Hey schaefer, when you get your 2nd gen. frame will you be making panhard drop brackets for us?
Thanks
Thanks
It's very possible, 2nd Gen is more likely than 4th at this point.
Originally Posted by anthony1
I'll vote for lifting the axle side. I've bent mine comming down on a rock when I had the 3" drop.
100% bolt on and extremely strong. Keep is simple and easy………………
Originally Posted by Goldrunner
Steve, what does the drop bar consist of? depending on whether procomp ever comes through maybe I should just cut my losses and go with the drop bar.
We send it back, we re-use what you already own to save on the cost.
Bolts into stock bracketry, the bar drops.
