my buddys nervous: 07 Camry Oil Change with loose filter-Damage?
he was doing a oil change on his o7 camry yesterday. drained the oil, just loosened the oil filter to drain that completly before he pulled it off. got side tracked filled the car with 6 qts of fresh oil forget about the loose oil filter and started the motor to cycle new oil. walked away and oil began pouring out the loose filter obviously. motor started clacking he said it (clacked probly 8 times before he got the motor shut off) drained every bit of oil but 1/2 quart. cleaned his mess up changed and tightned the new filter and added freash oil a 2nds time motor sounds ok would anyone think theres damage done
probably not, did an oil change today on a 99 crownvicp71 and she clacked about 10 times at startup, theres always oil residue in the cylinders, unless it was sitting for a few years(if it was i hope you learned how to change oil a bit faster LOL) , with the oil filter loose it was probably just low oil pressure and the valve rockers clacking, as long as its not clacking now, you'll be just fine
Yeah, I was in a rush one day and made it 8 miles away from Jiffy Lube (Church St., Nashville, TN) on my way out of town before a cloud of smoke blew out behind me. The oil filter fell off of my 96 Corolla. Had Jiffy lube pay for a tow and had the dealer check it out. For the first time ever, a dealer actually said nothing was wrong with a car (aside from cleaning off the engine).
jasonty
41
12-23-2018 01:00 PM
