Misfire after engine cleaning
So I cleaned the engine today (simple green and water). After cleaning, I'm getting what sounds like a misfire.
I pulled off all of the plug ends to see if there was water down the holes. Nothing. I'm going to take a look at the MAF and give it a cleaning.
Anyone know what the problem might be?
I know you checked the plugs for water but that's what happened to me when I first got the truck. Decided to get a detail and they blasted the motor w/ water and it would idle funny. They tried blowing compressed air into the spark plug areas but to no avail and eventually a CEL (didn't look up the code). After we swapped in new plugs, no CEL and it ran great.
BTW, you didn't get water into the airbox, did you?
No water into the airbox. I just shot carb cleaner over all the hoses to see if there was a vacuum leak, but to no avail. Cleaned out the MAF with electrical spray - no luck.
I tried putting my code reader on the truck, but the darn thing isn't being detected!...figures. And I need the truck by tomorrow morning, 10:30. I think I may be screwed.
New plugs and wires fixed it. 2 of the plugs had a little water in the holes, even though I blew the heck out of them with the air hose. Go figure. Thanks guys!
Originally Posted by Adam F
This happens to me every once and a while. Just driving around for 15 minutes or so will dry things out and fix the problem.
Iknow this old but this just happened to me on mt 01 SR5
I put a code reader on it and it showes a #6 cylinder miss fire a just checked all of the plugs and no water so i guess im going to get new wires and plugs and try that just hope on of the coils is not bad
Do any of you know what cly is #6
im still learing the Toyota
09-04-2015 09:27 AM
