Maglite Mounting 1982 Toyota
Here is my idea on how to mount my maglite on my 1982. I got the idea from 4crawlers site to mount the light up to the grab handle bolts via some mounting clips made by maglite.
For reference, on my truck (all first-gens, i believe) the screw size that worked was (machine screw) 12x24, I chose a round head. The only thing is that the mounting holes in the brackets are too small. I simply drilled mine out to accommodate the bigger screw.
Mounted:
My Maglite Installed (Silver 2 D-cell):
Finally every time I go around a corner, I won't hear it sliding around behind the seat!
Mounted:
Pretty sweet idea. Do you think a 3 D-cell would fit also? How secure is it? I wouldn't want one of those things smacking me in the head after a hard pothole at 70mph.
As for a 3-cell, I'd bet on it fitting. The clip positioning just may be towards the front of the lights. Oh, and in case your wondering there are two mounting holes, I arranged it to where the clip is on the back side of the bolt.
I was going to mention something about the security. When they say it holds your maglite securely, they ain't kidding. It "Snaps and Locks" into place. I thought they were for a c-cell light originally. When that light is clipped up in there, I honestly don't think It would fall. Ever. It may slide out if you hit a guy head on at like 75mph, but I think you would have bigger problems in that case. To put it simply, I would completely trust them. This weekend we are going camping so I will try it out on some rough roads and post results.
Sponsor
i just keep everything behind the seats.
too bad sweet home is so far from portland (i've moved to portland for a couple weeks).... i think it would be funny to get a pic of our two rigs together
Yeah i originally planned to place it behind the seats. But I figured up there would be better because I can grab it easier. Plus there was no handle there, so its no loss.
Tofer- that'd be awesome! Especially after I finish my $8 paintjob. Let me know if your down this way.
It's generally not a good idea to mount hard objects on the A pillars or around the windshield area unless you want your skull cracked open in a wreck.
This is why rollbars have padding
That's a NICE install....you may just want to get yourself a patent on that design...
But for my simpler "install", I just shove 'er between my seat and center console, and I'm golden.
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Suprarossa
07-06-2015 05:21 AM
