How do I remove paint from bumper and tail light?
Old 02-02-2006, 09:09 AM
Amir904's Avatar
How can I remove paint from the chrome bumper and tail light? Some wacko brushed up against me in a lot. Not too much damage, but there's all this white paint on the bumper and tail light.
Would rubbing alcohol work since I dont have to be scared about removing any paint below it?
Old 02-02-2006, 09:13 AM
Flamedx4's Avatar
Keep cross posting, someone is bound to answer...
(I know I know - with 218 forums to choose from, who knows where to put it so someone might actually read it...)
Old 02-02-2006, 09:43 AM
mdh
mdh's Avatar
How about some pre-cleaner / chrome polish or polishing compound?
Old 02-02-2006, 09:54 AM
callmej75's Avatar
Rubbing compound
Old 02-02-2006, 10:04 AM
FUZION's Avatar
rubbing alcohol - if that doesnt work rubbing compound and polishing compound
Old 02-02-2006, 11:09 AM
bamachem's Avatar
acetone works.
so does "scratch out" and "scratch away"
Old 02-02-2006, 12:16 PM
Flamedx4's Avatar
Acetone will damage your paint.
Acetone will seriously damage your tail light.
Not a good idea.
Old 02-02-2006, 12:21 PM
bamachem's Avatar
i've used it before on both. don't bathe them in it and there's no damage.
drench them and you're asking for trouble from ANY strong solvent.
Old 02-02-2006, 12:36 PM
Bob_98SR5's Avatar
EDIT: CORRECTED!!!
water + diluted nail polish remover in a 10 to 1 ratio (10 parts water to 1 part NPR)
bob
Old 02-02-2006, 01:31 PM
Amir904's Avatar
ill try the rubbing alcohol and see if that does the trick. thanks all.
Old 02-02-2006, 01:56 PM
FORANA's Avatar
Wd-40
Old 02-02-2006, 03:38 PM
Flamedx4's Avatar
belt sander
Old 02-02-2006, 06:22 PM
Junior Member
tpg013's Avatar
If it's just paint that scraped off the other car, you should be able to get it off with clay or any good paint cleaner. I'd stay away from the compounds unless you have the time to work the scratches out they leave behind. I've never been a fan of harsh chemicals either.
Eithe rthe clay or the paint cleaner and some elbow grease should do the job.
Old 02-02-2006, 06:38 PM
HUTCHSTACO's Avatar
just try a cleaner wax, steel wool on the chome bumper will get the paint off, it works greak on chrome
Old 02-03-2006, 05:54 AM
Amir904's Avatar
rubbing alcohol worked fine.
Old 02-03-2006, 06:20 AM
lee
lee's Avatar
Originally Posted by Bob_98SR5
diluted nail polish remover 10:1 (np:water) ratio
bob
bob is dead on...
http://4runner.kidmoe.com/parking_woes.html
Old 02-03-2006, 06:23 AM
bamachem's Avatar
guess what nail polish remover is... ACETONE... :pat:
good idea about just diluting it w/ water, and i'm glad it worked for ya.
however, is it 10 parts polish remover to 1 part water
-OR-
10 parts water to 1 part polish remover???
the way bob posted it was 10 parts polish remover to 1 part water - which barely dilutes it at all (about 9% dilution) and is basically full strength.
Old 02-03-2006, 07:00 AM
lee
lee's Avatar
oh i did 8 parts water.
found that to be weak.. so i added more remover.
Old 02-03-2006, 07:13 AM
Junior Member
tpg013's Avatar
Steel Wool !!!
No way unless you want a zillion scratches. the only steel wool I MIGHT try is 0000 Steel Wool. Even that I'd be hesitant with.
Clay it. It'll work.
Old 02-03-2006, 07:50 AM
Flamedx4's Avatar
Leave it, it adds character...
Quick Reply: How do I remove paint from bumper and tail light?
