Engine wont start, bad solenoid?
Old 07-07-2006, 03:33 PM
1985 4Runner's Avatar
For those that don't know, I have a Chevy 350 in my 4runner out of a '76 Vette.
The last few days it was hard to start & I had to jump start it a few times. Checked the battery & it was good. Now it just clicks when I try to start it, wont turn over at all.
This is just clicking when I try to turn it over:
I start checking connections & find this:
I don't pretend to be some master mechanic, so flame if you want to, but what the hell is that part?
Can I change out the solenoid or should I replace the starter?
Anybody with the V-8 swaps/experience out there had this problem?
Old 07-07-2006, 04:41 PM
bob200587's Avatar
is it an external solenoid? If it's simple, take the starer off and look at it. One of mine locked up on me, and another some teeth were chipped, and thats why it wouldn't work.
Old 07-07-2006, 06:03 PM
ironroad9c1's Avatar
dude that starter is junk ,with that hole in the case water and dirt are all up in the case and bearings , get a new one ,its just a high torque gear reduction stater
get one from summit for 139.95 or you could try and fin d a place mear you that rebuilds starters and alternators , but last i had one done was close to 100 bucks so prolly better off getting a new one.
Old 07-07-2006, 06:05 PM
also find a bellhouseing cover .
Old 07-07-2006, 06:12 PM
4runnermt's Avatar
That part is a starter relay. It can be the problem. Theyre like 30 bucks.
Old 07-07-2006, 06:22 PM
4runnermt's Avatar
I was just looking at your pics again, and all of your wire connections are crusty and rusted. I would clean these off too and maybe put some dialectric grease on them. It would be a good idea if you don't have one to get a bellhousing cover to keep all the crud out.
Old 07-07-2006, 09:25 PM
thanks, I got the same advice about the bellhousing cover on another board.
Old 07-08-2006, 01:48 PM
you can remove the starter and see if you can take it apart and clean out inside ,but that hole in it isn't helping things.
Old 07-18-2006, 04:28 AM
Update, pulled the starter off yesterday & went to a local shop that was highly reccommended. The owner took it apart & the bearings were bad (among other things). It can't be rebuilt, so he is going to pull the tooth gears out of the old (11)then install them in the new starter(9), remount the adapter plate & then I should bolt it back on.
Old 07-18-2006, 11:29 AM
Done, problem solved.
Bolted back on & fired right up.
JF9243176
10-08-2017 04:21 AM
91toybeater
12-27-2015 07:46 PM
Ichneumon
09-27-2015 04:21 PM
bigblue82
10
07-06-2015 08:27 AM
Alex Bessinger
06-28-2015 10:05 AM
Quick Reply: Engine wont start, bad solenoid?
