Electric Cooling Fan - 91 4-Runner??????
Old Apr 2, 2009 | 03:29 PM
revbrad's Avatar
Just wondering if anyone has converted a 91 4-runner to an electric cooling fan system and if any kits are available.
Old Apr 2, 2009 | 06:25 PM
RobD's Avatar
I'm about to do mine, hopefully this weekend, with a Flex-a-Lite kit.
Old Apr 2, 2009 | 09:09 PM
Steveh29's Avatar
I used to have the Flex-A-Lite black magic fan on my truck but I had overheating problems. I would overheat on long uphill runs or if I was crawling - basically any time the engine was under load, working hard. The Flex-A-Lite fan would be running but just not pulling enough air. I suspected everything but the fan. Replaced the radiator, hoses, thermostat, and finally in desperation put the factory fan and shroud back in - and that solved the problem. I later found I'm not the only one with this problem and many folks had bailed on their Flex-A-Lite fans. Some folks have good luck with electric fans but for the hassle and no percieved increase in performance from the engine - I went back to the factory set-up.
https://www.yotatech.com/forums/f105...x-165-a-63155/
Old Apr 2, 2009 | 09:30 PM
RobD's Avatar
Awww...crap.
Well, I guess I'll find out this weekend. Good thing my brother works at the autoparts store where I got everything!
Old Apr 3, 2009 | 06:08 AM
revbrad's Avatar
Thanks
With this in mind I think I will just replace the blade on my clutch fan - that is what happened my blade shattered and took out the shroud and upper hose
Old Apr 3, 2009 | 11:32 AM
mt_goat's Avatar
Taurus fans are about the most powerful that will fit on our trucks. Many have used them successfully.
Old Apr 3, 2009 | 01:41 PM
Adam F's Avatar
use the taurus fan. i cool my 350 with one, mounted on the front of my rad, spinning in reverse.
Old Apr 3, 2009 | 01:59 PM
swaycleveland's Avatar
taurus fan in mine havent overheated once! taurus fan puts out up to 4200 cfm
they also can be bought for 50 bucks
i do use the felx a lite vsc ( varible speed controler)
which is a must the taurus fan uses 80 amps
a varible speed controler ( any brand) will slowly bring up the speed and not draw 80 amps at start up
Old Apr 3, 2009 | 03:39 PM
stagger_lee's Avatar
I have the pep boys special. I think it was the top of the line pile you can get from pep boys at a whopping 14"s. I guess it depends on what motor you have, but my best upgrade was to a heavy duty 3 core aluminum radiator. I run about 185* in dead traffic and 95* outside. Most of the time I run with the fan off. This is a 22r though not a 3slow. I love my e fan.
Old Apr 4, 2009 | 05:40 AM
Adam F's Avatar
I have the taurus fan running without a "speed controller". I use a cheap autozone adjustable temp controller ran to a standard Chevy style starter solenoid and then straight to the fan, on high speed. I have a 60 amp alternator, and the voltage never drops below 13.8v, even on startup.
Old Apr 4, 2009 | 09:28 PM
Stick_Figure's Avatar
i used a couple permacools, and did a custom fan shroud for my 3rd gen. For trigger, i used a Honda (shhh) 190°f switch,then for power a couple relays, and a circuit breaker.
I can say so far no overheating or anything close, and the AC has never worked so well!
Old Apr 5, 2009 | 06:04 AM
mt_goat's Avatar
Nice work
I also made a shroud for my Taurus fan:
Old Apr 6, 2009 | 08:01 AM
Windsor's Avatar
Regarding the flex-a-lite BM-150, the general consensus in other threads was that the 3.0 would tend to overheat, but the 22RE should be ok (if installed properly, yadda yadda).
Old Apr 6, 2009 | 08:36 AM
Adam F's Avatar
Why would you pay $200-$300 for an electric fan that inadequately cools, when you can buy a $30 junkyard fan that cools MUCH better?
Old Apr 6, 2009 | 10:28 AM
Windsor's Avatar
junkyard rattlesnakes!
To me, it would be worth the extra $170-270 to not get bit.
Actually, I already have a BM-150 laying around, used to be in my '83 RX-7.
Old Apr 6, 2009 | 10:38 AM
Then pay $50 and have it pulled for you. I wouldn't use the BM150 on a 3.0. Sell it to buy your taurus fan.
Old Jul 12, 2009 | 06:35 AM
ShortyzKustomz's Avatar
I know this an old post, But if anyone else needs a Taurus fan then are under $30 a piece at 2 yards locally, they have about 15+ Taurus' in each yard
Old Jun 20, 2010 | 09:46 AM
barthmonster's Avatar
how much for a NEW taurus fan (aftermaket okay) ?
where is the temp-switch on a '91 4runner that turns the fan on ?? (I need to check it)
I have the 3slow and it runs hot on warm days running at low rpm. Cools when revv'ed to 4-grand. Side note, this 4Runner appears to have a normal engine-driven fan with a hydraulic fan-clutch (just replaced) AND a small electric fan. Don't think that big taurus fan will fit in place of this small electric one...
Thanks in advance for any help....
Old Jun 21, 2010 | 05:41 PM
RobD's Avatar
There is no temp switch to turn on an mechanical fan. They're clutch actuated.
If you do the Taurus fan swap, you'll need to pick up an electric fan controller, kinda like these:
http://www.jegs.com/c/Cooling-AC-Hea...11471/10002/-1
The "small electric fan" you speak of is for your A/C.
Old Jun 22, 2010 | 04:36 AM
I'm sorry, I meant the small electric fan that on my '91 4runner sits in front of the A/C condenser.
Am I the only one that has a Hydraulic fan clutch and also a small electric fan too ???
My little electric fan doesn't work, but the Hydraulic Fan clutch was just replaced, and I still overheat now and then. Where is the 'switch' or whatever turns on this little electric fan ??
Thanks guys !
