Calling Diesel Heads- Toyota OEM oil centrifuge
Howdy Mates:
I read somewhere - 9month or more past - that Toyota was installing an oil Centrifuge on either 1KZ-TE or the new 1KD-FTV
Anyone know anything of what I am speaking of
Land Rover has a supplemental centrifuge on the TD5 - spindle requires replacement at scheduled intervals
Cheers in advance
Cheers in advance
Howdy Adam:
many of the large lorry types as well as big diesel - locomotive etc. use these - I have a large one to be fitted to my full size pickup - the return pipe to sump pan is 3cm - over and inch - so as not to stall centrifuge - powered by oil pressure 3- 5 bar
a bit big for me to install to a 4 banger diesel
i am certain I read a few posts somewhere - Hilux AU. site is still down - joined the Offroad Pakistan forum - those guys know diesel engines-
Land Rover has a supplemental one on the TD5 engine - is supplemental - spindle replaced at scheduled intervals - filters to 3 micron - works in tandem with main can filter - many seem to think it would not be possible to retro fit onto different vehicle as is specific to TD5 oil cooler
i dig the idea of filtering down to near blood corpuscle size and never have to worry about recycling an oil filter
will share what I find out :
Cheers:
Cheers:
Howdy Roy;
Do you ask on Toyota or Land Rover - I am only certain TD5's have -
it should look like a tiny grain silo - maybe the size of a tea cup - most probably mounted/attached same side as oil pressure sender OR where oil cooler is mounted to side of block- same side as intake manifold
Cheers
Cheers
FS[MidWest]: 2010 Toyota Tundra DC $24500 OBO Bismarck ND
toy89yota
06-24-2015 01:18 PM
scotts93
07-18-2002 04:10 AM
