What weight oil should I use?
Old 09-20-2010, 01:29 PM
  #41
dbcx's Avatar
Originally Posted by Teuf
I don't think that thicker sticks better, and thinner does NOT expose metal to metal. Remember 22re's are noisy. Good flow at start up means protection, and flow = cooling.(http://www.ferrarichat.com/forum/faq...=haas_articles) << google that, good oil basics
This is a good article if you read it, it is a long read but very good. Oil arguments go on forever. The thinner at startup will be better, the majority of engine wear is at startup, you dont want to be pushing honey thru the system every morning. I run 5w oil in everything i got tho year round here in georgia. BTW 5w-30 and 10-30 are almost identical at operating temps, thats in that article also
Old 09-20-2010, 05:19 PM
  #42
brian2sun's Avatar
My oil is dropping a weight class. Hopefully it will get a title shot at middleweight.
Old 09-20-2010, 07:15 PM
  #43
1995yota's Avatar
yeah, and apparently synthetic 10w-30 is thinner at room temp than mineral 10w-30 So even just switching to synthetic would help the situation out at start up.
Old 10-03-2010, 07:04 AM
  #44
pruney81's Avatar
I just changed over to Shell Rotella T6 5W40 Sytnthetic about 6K miles ago on my 22RE and it didn't cause any leaks or loss of oil. But, I didn't have any of those issues before. I noticed out here it cranks up much easier on cold mornings. The diesel oil also has ZDDP which is good for our flat tappet engines. It's also only about $20 for a gallon at Wally World in my neck of the woods.
Old 10-03-2010, 08:00 AM
  #45
Resto-noob's Avatar
Rotella T6 5W-40 is what I run everything on in the winter. My 22R plow truck is running 15W-40 Rotella or Delo 15W-40.
The only reason I run Rotella is because I drive a diesel pickup and it's easy to get for roughly $10. a gallon at some point throughout the year. Back when I was a full size Jeep guy, people touted the detergency of diesel motor oil...While I've never had an oil analysis done, lots of people have gotten good results with it. Hell, if a diesel motor doesn't shear it, could a 22R?
Old 10-19-2010, 10:58 AM
  #46
1995yota's Avatar
Diesel oils have special additives in them mainly zinc, or so i've heard. But i'm planning on switching to synthetic my next oil change, I was going to go with Redline 5w-30, but it's a PITA to get around here, and i've always been a castrol person, and they just came out with the new Castrol EDGE full synthetic, which IS available in all the auto stores around here and I was gonna use a K&N filter. Any body used the stuff and know how it runs?
Old 10-21-2010, 04:15 AM
  #47
pruney81's Avatar
Shell Rotella T6 5W40 Synthetic. $20 a gallon at Wally World. And I run a stock Toyota filter.
No idea on the new Castrol Edge, but I did a ton of research on oil and finally settled on the Shell synthetic. I'm sure the Castrol is quality though.
Old 10-21-2010, 10:35 AM
  #48
mitfan311's Avatar
20w - 50 in Memphis. Old engine high miles. It doesnt get that cold here. summers are in the 90-100s. My dad as an old school mechanic thinks it is just a good precaution on and old engine. It actually quiets the engine down a little. Plus it will slow leaks some i guess. In theory it would actually rob the engine of power since it takes more effort to push thick oil through the veins of an engine. Like think blood on a heart. Thats why we give aspirin to people who are having heart attacks. It thins the blood and makes it easier for the heart to pump. But dont put aspirin in your oil.
Old 10-21-2010, 12:26 PM
  #49
richf's Avatar
Interesting info. I just put in castrol HM 10w40 on my last oil change. I think I might try the 20w50 to see if it helps quiet the engine a little. What temp range would you suggest not driving with this oil in? Also Most of my trips in cold weather (30-50F eastern shore VA) will be short distances (2-3 miles). I'll let the truck warm up a little bit before I take off but it may not be fully up to temp.
Old 10-21-2010, 09:31 PM
  #50
1995yota's Avatar
Yeah, shell does put out quality products, I think i'm going to try the EDGE though, it supposedly protects 8x better than Mobil 1 and my mom has used that and fram filters in her Rodeo for 140,000 miles, and almost never changes it, yet somehow, it runs like brand new. I'm actually dropping a grade in my oil, I can deal with some engine noise, if it means I get oil over my cams and rockers faster.
Old 10-21-2010, 09:49 PM
  #51
JDS1992's Avatar
I run 10W-30 Valvoline Fully Synthetic, In my 92 because it doesnt really get to cold here. In my 99 I run Conventional Mobil 1 5W-30 Personally I like Synthetic more..I believe that most synthetic oils are mostly the same. I just look at the Specs of the Oil on the back. I prefer to use Valvoline ,or Castrol Fully Synthetic. So just figure out what oil you like and stick with it.
Old 10-22-2010, 03:37 AM
  #52
pruney81's Avatar
Yep. figure out what oil you like and stick with it and change it consistently and you'll be good to go.
okamikai
04-30-2018 10:19 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Toyvana
07-29-2015 10:47 PM
calderp
07-27-2015 09:58 AM
Quick Reply: What weight oil should I use?
