weber help to lean
Your not supposed to change the main jets, only the idle jet. Did you read the above mentioned procedure on how to tune these? I bet that "tech" on the phone didn't. If you asked him what lean best idle adjustment meant, I bet he wouldn't know.
#27
na that's fine, if your gonna tear apart the carb to check all the jets you might as well get a rebuild ki for it. My guess is that the guy ran it for a month because he didn't know what he was doing and got rid of it. Which is typical of someone with a weber. As alot of people slap the thing on don't read the directions that come with it then bash the carb. I have had 0 issues with the carb on mine, just the crappy two-piece adapter which I remedied this weekend buy using the 1 piece transdapt adapter. Oh and the occasional stalling when off-road but that;'s to be expected from most carb's that haven't been modified to handle bouncing around and such.
#29
I woulda looked to see what you are working with inside that carb or ask him what he did with it and exactly which jets he changed before spending 4-5 bucks a piece on jets I didn't need. As far as the transdapt I've only drove it once with it. See my build thread at the end.
