ubolt flip
ubolt flip
I have come across this tech tip. It is a simple bolt on app. The Issue I don't see addressed is where do you mount the shocks. Will you need different shock lengths? Is there a bolt on for the shocks?
You will need to relocate your shocks which will require welding. The flip itself is direct bolt on though. I just torched some plates out of flat stock and grabbed some round ubolts from an older chevy half ton
The most popular shock layout (the one i chose) is the triangular design. When you hit something like a speed bump or a rock it acts just the same as a standard factory layout but when you're flexing it allows a lot more upward and downward travel.
You could use your factory shocks if you wanted, it's all about where you weld the mounts on. Just measure, measure and re-measure to make sure everything is where you want it.
Heres mine (I was in a hurry to get 'er done so i boogered on some lame ass mounts but you get the idea) Yes one is broken but just pretend the right side looks like the left side
Here are the ubolts and plates
It would be a little cleaner if you bought some of these
http://www.wabfab.org/products/suspe...ltflipkits.htm
And you dont have to get all fancy with it but something like this with more contact area with the axle housing would be ideal.
Shouldnt be too expensive to hire a welder or have a shop set this up for you if you arent set up to weld
I know the shock mounts are crap, i knew it was crap when i made it. It was like 2 in the morn. day before wheeling i just wanted to slap it together as fast as possible
Edit: Oh and yeah it's a major project she's all torn apart getting a bigger newer better motor.. the wiring is torn apart and everythings getting re-arranged so it looks kinda chaotic
I used a bolt-on lower shock mount:
- http://www.4crawler.com/4x4/4R_suspe...shtml#R-Shocks
They bolt to the bottom of the spring pack and are held in place by the u-bolts:
And yes, I know the springs are reverse arched there and yes, I do have a bump there, but I found that it folds over in extreme conditions like this.
FS[GreatLakes]: $180 BJ Spacers, 1.5 Rear Lift, Rancho RS5000 Shocks
jaretstuff
10-22-2015 05:25 PM
scott90
10-04-2015 09:21 AM
sonorn67
09-19-2015 05:39 PM
