total chaos 6 lug uniball lt kit on 91 2wd
im totally new to the world of toyotas. im goin to look at a 91 2wd yota, that i plan useing a tc uniball 6 lug upgrade kit. the shocks will be 2.5 king coil overs with 10" of travel. to eliminate the torsion bars.king kong steering, pretty much all suggested accesories. anybody have a similair set up? got part numbers? wheres a good place to start with spring rate. i plan on goin big on jumps. what should i do for rear? im thinking deavers? spring under. what about shocks? im thinkin i mite even compete in the 1450 class eventually.
I would suggest checking out the several pre-running and desert forums. you would find the most applicable information that you are looking for there. welcome to Yotatech. There are a few member that share you avenue of off-roading here on YT.
priest16
15
08-06-2015 07:43 AM
