| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Timing issues
#2 (permalink) |
a somg station would never check "cam" timing...so stop looking there...if your "ignition " timing reads way off then your tps is prob not adjusted right or defective. Before you put the ecu in by pass mode check the timing. Then after you put the ecu in bypass mode confirm the timing retarded. if it did not then the ecu is not going into bypass mode..fyi,if it passed emissions then the chances are your cam timing is ok.
__________________
www.davezoffroadperformance.com for all your new and used toyota truck and 4 runner parts 530-622-2148 Dave |
#3 (permalink) |
When my two cam marks are lined up ( straight up) and the #1 piston is at TDC on the cpmpression stroke, should'nt the timing mark also be at 0 TDC? cuz it's not! it is about 2.5 inches away from 0 TDC. And the rotor is not pointing at #1 in the dist cap.
#4 (permalink) |
How do I remove the dampner without turning over the motor? I do not have an impact driver.
#5 (permalink) |
I just read back on some threads on how to remove the crankshaft bolt. Does the starter trick really work? It seems something would break.
#6 (permalink) |
It's the only way to go if you want my opinion, sans impact driver. Unless you can rent or rig up the SST to hold the pulley still.
I'm at a complete loss as to how your engine could run being that far off.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 07-15-2007 at 06:27 PM. |
#7 (permalink) |
Here are some pics.
#9 (permalink) |
This is how it is right now and runs great!
#10 (permalink) |
I see. That big ol' notch isn't the mark. It's much smaller (red arrow).
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! |
#11 (permalink) |
To get the crank pulley bolt loose, put a wrench or ratchet long enough to reach a frame rail or other solid part and "TAP" the motor over.
__________________
My rig: slow 84 longbed 22r, locked in the rear, headers, bed riddled with cancer, and mt 31's Have locker, will travel. |
#12 (permalink) |
I just went out and looked again. Thats dirt where your arrow is. It was a Toyotas only shop that told me it is 77 degrees off. I am pretty sure the groove is the timing mark (according to the book).
#13 (permalink) |
Well, it's been tampered with. The mark is not supposed to be a wide notched V shape. It's smaller, about 1mmx1mm, like half as big as that or less even. Check under the dirt, cause that's where it should be anyway.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 07-15-2007 at 10:31 PM. |
#14 (permalink) |
I just got the crank bolt off using the starter method. That is freakin crazy!! Anyway, my crank sprocket marks are lined up and my cam marks are lined up so I am going to put it all back together. I am hoping that it is my distributor that is off a couple teeth.
Thanks all!! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| timing belt issues | budro | 86-95 Trucks & 4Runners | 3 | 05-19-2007 05:12 PM |
| timing issues | tampabayota | 86-95 Trucks & 4Runners | 5 | 02-12-2007 11:41 AM |
| 22RE Timing Issues! | SupraSport | 86-95 Trucks & 4Runners | 23 | 01-28-2007 02:04 PM |
| Timing issues... | MarkH1121 | 86-95 Trucks & 4Runners | 8 | 12-05-2006 10:03 AM |
| have some ign. timing issues. . . . | MightyToy | 86-95 Trucks & 4Runners | 3 | 02-28-2006 10:23 AM |
