sliders before or after body lift?
Old 11-24-2009, 10:30 PM
Quagland's Avatar
If i weld some sliders on and then lift the body would it end up looking wierd?
like
before lift
body
------ Slider
after lift
body
-------- slider
would something like that end up happening?
Old 11-24-2009, 11:09 PM
NwRunner's Avatar
yes.
more than an inch would probably look weird in my opinion, but its all about function with sliders.
Old 11-24-2009, 11:21 PM
olharleyman's Avatar
Do them after that way you can adjust your weld point on the frame to make them look like the b/l is not even on it then add gap guards to cover the see through frame area.
Old 11-24-2009, 11:32 PM
drew303's Avatar
definetly after
would look BAD if you did it prior. With no body lift the sliders have to be welded at the VERY bottom of the frame.. I have a 2" BL and the sliders weld to the center (with scab plates and gussets) ..much stronger and looks way better IMO
Old 11-25-2009, 09:42 PM
Quagland's Avatar
Originally Posted by drew303
definetly after
pics pls cause im gonna do a 3" BL
Old 11-25-2009, 09:54 PM
stormin94's Avatar
I'd say after, since you might have problems accessing the body mount bolts with sliders welded on.
Old 11-26-2009, 03:06 AM
85TurboRunner's Avatar
After would probably look the best, but if you ever decided to remove the body lift you would have to cut the sliders back off and re-weld.
Old 11-26-2009, 08:13 PM
brian2sun's Avatar
No brainer IMO. 3" of gap would look horrible.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
priest16
15
08-06-2015 07:43 AM
upongame619
08-01-2015 12:12 AM
Cabell
07-24-2015 12:14 PM
Quick Reply: sliders before or after body lift?
