Shock Relocating?
Shock Relocating?
So im going to relocate my rear shocks like in the picture....but can I use the bar thats already there? Or will those angles be unheardof? Cause it sits further forward than the axle.
the reason for locating the shocks like in the pic is to fit a longer shock in a small place and kind of reduces the shocks dampening capability so if you moved them inward and then forward ude have a long shock that didint dampen a whole lot
Ok because I wanna run the Bilstein 5100 Shocks in the back with a 4" lift but idk if 4" is high enough to use those and still have enough up travel.
what size travel shocks are they? you can measure your shocks "colapsed length, and extended length..then just add 4-5 " to that and you should be golden..or more if you have flexy springs...most of the time people running shocks like the above is because they have ALOT of down travel and not alot of uptravel basically running no lift with more flexible springs...so if your running lift springs or blocks 4-5" bigger shocks should be no problem
ok cool...yeah im going to be running the RC 4-5" lift and going to be doin a Ubolt flip and thought about the relocatin of the shocks. But if they should be fine then im not gunna worry about it.
huh? didn't get the first part, but look at the second photo carefully, notice the u-bolts are upside down? Disregard the lift block in there though. You might have to move the brake line a little around it, I don't know. But if Bud Built sells this, I don't see this setup not working.
dirk89
10-01-2015 05:15 PM
hiluxinargentina
09-30-2015 05:51 PM
