Sequoia keeps stalling
We have had some compressor seizures on those. Maybe its tight, and when it cycles on, load is too high, stalls the engine? Will it do it if the AC is off and the vent is moved to feet? (keep in mind, AC runs in the 2 defrost positions, even if the AC is turned off) if it is the AC, you can unplug the pressure switch on the AC plumbing to disable it till you get it fixed.
charlie_fong
09-27-2015 10:06 PM
