School me on sliders
Okay, I'm sure this is a repost, so I'm sorry to all you people that get sensitive about that. But I have been trying to find something with the info I want on it and im not having any luck
So I just recently got a new rig. 86 pickup, standard cab with 6 inch lift on 33's. I have had it out once just messing around. Something I'd really like to do before i mess it up to much (cause the body of the thing is pretty straight, minus a little rust on the bed) is to get some rock sliders for it. Buttt in all honesty, I have NO CLUE what I'm doing. So I'm looking for suggestions, what brand, do i get the extra gussets (i think thats what they're called) or what? Any info would be much appriciated. Thanks
-Scott
P.s. sorry for any misspellings, i go to public school...
-Scott
Allpro offroad, 4Xinnovations, Marlin crawler, Trail Gear, CBI offroad, Crawlin concepts...
Tons of companies make rock sliders. Google will turn up more names than I just listed, for sure.
Deff get the scab plates and gussets to go between the legs and the frame. It just makes them that much stronger. No reason in doing them twice
definitely get the gussets and plates as suggested by Scuba. One this to consider is the Kick out towards the rear, it has kept me from doing damage on a couple of occasions:
I had Stubb's slider on my '05 Taco...great stuff
Adam makes a great product, well tested:
you can just see the slider
a little paint after that episode and they were good as new:
You mentioned you have 6" lift. One thing to consider is, if any of the lift is from body lift, you may want to specify this when you do purchas sliders. Most manufacturers will make appropriate adjustments to the sliders to account for the body lift if requested. Otherwise you will have a space between the sliders and your body.
ocdropzone, can i get a guestament on those sliders?
And no body lift, thats yucky.
Edit: whats the difference on the HERW and DOM sliders from 4x innovations? i looked up the price after posting this, i relised what google is and took about 30 seconds of my life and found it myself haha
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Another great unexpected feature of a Toyota
Plenty of room and nice flat surfaces to weld on sliders
Ideally the reason for sliders is to protect your cab when you roll on a high centered obstacle.
...And you want them strong enough to support your vehicles weight.
tried4x2signN brought up some great points. Installation is easy to do on Toyota frames and you want them to be strong enough to support your vehicle's weight.
Most suppliers nowadays supply triangle gusseting which spreads the load greatly increasing the effective contact area at the frame rails. You'll want to install at least 2 gussets per leg in a V-configuration, like this:
O
...to add extra support to combat upward bending moment forces. If possible, I'd add a 3rd gusset positioned downwards at 6 o'clock.
I am running Marlin Crawler sliders and I can pick the entire side of my truck up from any position along the slider while still being able to open/close my doors (slider does not yield into the body). I have dropped off a ledge so hard onto my slider I got a mild whiplash! Thank goodness they are there!!
I've been using the same Marlin Crawler sliders since 2004 and my cab owes it's life to them! Seriously. I cannot Rock Crawl without them!
Dropping into off camper holes becomes less worrisome...
Works great in tandem with flat belly setups...
Regards,
BigMike
O
Regards,
BigMike
wow bigmike didnt know you were over here! i was just about to say, go marlin, a buddy of mine has marlin bumpers and sliders and they have saved his rig on more than one occasion.
I've got some pictures from Dusy/Ershim scattered throughout pages 2 & 3 of my gallery thread: BigMike's pictures. Just like any other thread regarding my truck, it needs to be updated
I've been a member since before the dawn of time & finally decided to start contributing We also would like to start posting specials and new product releases but I want to get settled in first
BigMike
Need some welding done let me know, i'm just down in Yelm.
I would recommend welding some C shaped brackets to your frame and weld the sliders to the plates with gussets. Otherwise the welds will just tear out of the frame as it isn't very thick. Just try to shoot for as much weld area on the frame as possible.
O
Regards,
BigMike
O
Regards,
BigMike
You know I've never been there, but there is one: https://www.yotatech.com/forums/f151/ I just realized we both joined the same month in 2002. I know you're probably busy with your own site but hope to see more of ya.
P.S. I'm loving my turtle knobs
Is it wrong to want to eat sushi off of a person? Or for that matter off of the belly of a Toyota??
