replacing shock bushing?
hey guys, i just found out that the bushing on my front shock is worn out, i have a 2002 tundra trd, with bilstein shocks in the front, i was wondering if its possible to change the bushing instead of buying a whole new shock? and how hard is it to replace this bushing?
I've replaced a bushing in a set of Bilsteins, or at least removed the bushing and put in a different sized sleeve:
So it is physically possible, the question is whether you can find a replacement bushing, give Bilstein custom support a call and see what they can come up with.
The Bils. bushings are different than others I have seen, Rancho shocks use a sort of hour glass shaped bushing, KYBs use a straight sided rubber bushing without the end flanges that the Bils. bushings have.
Measure what you need and see if any of them will fit. Energy Susp. might be a place to try:
- http://energysuspension.com/products...-Bushings.html
Or call up Bilstein, I've found their customer support to be awesome:
- http://www.bilsteinus.com/contact.php
TURBOrunnerNM
07-22-2015 11:01 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
