Polyurethane vs. Aluminum spacers for lift?
Old 08-23-2006, 12:36 AM
clyderiver77's Avatar
Hello, I have a 2000 4runner V6 Sport 4X4. Looking for a little lift, without a harsh ride. If anyone could please let me know what material they favor, I'd appreciate it. I need to purchase these tomorrow, so please help fast. Thanks!!
Laura
Old 08-23-2006, 02:14 AM
rocket's Avatar
Polyurethane.
Old 08-23-2006, 02:32 AM
AH64ID's Avatar
Personally I am not sure it makes a difference..... I used aluminum and didnt notice a change in ride quality. But you might get a bit softer with the poly....
Old 08-23-2006, 03:51 AM
Firefightertaco's Avatar
if your gona use spacers its gona make it a rough ride anyways and even worse if u still use your stock shocks.
Old 08-23-2006, 04:12 AM
AH64ID's Avatar
How do spacers affect the ride? The spring rate isnt changed. The spring isnt compressed, its just put lower in the struts axis, this raising the vehicle.. but spring rate is affected, nor is ride quality...
Old 08-23-2006, 04:27 AM
waskillywabbit's Avatar
Never purchase in a rush.
Is this a body or susp lift?
Poly.
Old 08-23-2006, 04:39 AM
Intrepid's Avatar
Most spacer lifts will be partially in the coil and partially above the coil. So it does preload the spring, but also moves the strut down. Of course, I assume we are talking about coil spacers, if not...well...
Swim
9
01-04-2016 10:47 AM
09-04-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
4Runnin2000
07-29-2015 06:09 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: Polyurethane vs. Aluminum spacers for lift?
