poly body mount questions.
Had them for 10+ years now, no regrets:
- http://www.4crawler.com/4x4/CheapTri...shtml#Bushings
Very little difference in ride quality, only change is a lot less rattling and shuddering when hitting big bumps in the road since the body is tied more tightly to the frame. No squeaks if installed right, to have a squeak, you need to have two parts moving relative to each other. If body mount bushings are moving under the body, your bolts are not tight enough, period!
Put mine in with 4crawler's 1.5 inch body lift but haven't driven it to test it out yet since my 3.4 swap isn't done... Made sense to do it then since I was there, my originals had 270k miles on them!
defrag4
07-31-2015 10:50 AM
