need some tire help
need some tire help
hello I'm new here and I've been through some of the threads trying to figure out what the largest tire is that I can go with on my 96 Tacoma. I'm looking at going from a 15" rim to a 16" rim and I'm good up to there but when I start reading all the numbers that everyone posts for tires I start to get lost. I'm used to the numbers for street tires and getting a little confused with all these other numbers. Anyway what I would like to do is go with the biggest tire I can without having to do any mods as far as a lift kit right now. I have to many other things that I need to do to my truck first. thank you p.s. not sure what gen my truck is so if someone could tell me that I would appreciate it. again thanks for the help
This site might help. on the right hand side it shows the smallest and largest tires that you can fit on a stock 96 Toyota Tacoma. it is Largest tire size: 265/70 R16
Here is the link so that you can check it out. generally a 30-31 is the largest that you are going to be able to fit without rubbing or a lift.
http://www.wheel-size.com/size/toyota/tacoma/1996/
Also here is a site that converts the tire sizes into more readable format. It can be a pain to figure out what size some of the normal truck sizes convert to.
http://tire-size-conversion.com/
Your truck is a 4th Gen in forum talk I believe.
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
