need some info on what to do with 2000 tacoma
Old 04-05-2010, 02:38 PM
Izzy03's Avatar
i have a 2000 tacoma prerunner and i wanna know what to do with the rear end whether to put a locker and if so which one or the TRD rear transplant
Old 04-05-2010, 03:09 PM
brian2sun's Avatar
How would we know what you should do with the rear end of your truck, that's for you to research and decide yourself isn't it?There are lot of questions to ask yourself that we just wouldn't have the answers for, like "What do you need it for?" or "Is it a DD?". I'm sure you'll get some suggestions, but this topic is heavily covered on a daily basis so try searching for 10 seconds and I'll guarantee you'll have an hour's worth of reading to do on diff lockers. BTW, you can't retrofit an elocker into your non-elocker axle - all you can do is an entire axle swap.
Old 04-05-2010, 05:13 PM
Izzy03's Avatar
alright my truck is a daily driver but i just want to ba able to rotate not just one tire but both at the same time and i have been told that i could just add a locker to my truck which is a 2000 prerunner
Old 04-05-2010, 05:32 PM
GranVille-4crawler's Avatar
Get an aussie locker
Old 04-05-2010, 05:38 PM
Izzy03's Avatar
where would i find an aussie locker at
Old 04-05-2010, 05:41 PM
The gettin place....
Old 04-05-2010, 05:48 PM
Izzy03's Avatar
which is where i was eading up on it and i can only find it for 4 bangers does it matter
Old 04-05-2010, 05:53 PM
Other brands are detroit, arb. Do some a search and see what ppl say. Its all pesonal oppinion. Detroits are good but pricey
Old 04-05-2010, 06:16 PM
Izzy03's Avatar
yeah i understand but i just dont know where to look online for them and i dont want nothing crazy just something decent and reliable
Old 04-05-2010, 06:24 PM
the vendors on here.... google search... and there is a search button at the top... use it
Old 04-07-2010, 12:05 PM
thebrick's Avatar
damn i thought that this was the newbie section...
you can get a clutch type locker, they are tough but a little harder to live with. look for detroit lockers and that type of thing.
you can get a selectable locker, like the one toyota has (which you should be able to put in as long as you have the right gear ratio in an 8" axle, which almost all toyota trucks have) and is more livable. It would take a little axle housing modification though.
you could get an air locker, like an ARB. selectable locker are more expensive.
Old 04-07-2010, 01:48 PM
brian2sun's Avatar
If he can type the words on his post, he can type those same words into a search engine, right? The Noob section still asks that you at least TRY to find an answer before you ask us to spoon feed it to you.
DeathCougar
04-01-2018 11:29 PM
Tonetrk
08-03-2015 08:47 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: need some info on what to do with 2000 tacoma
