my starter problem....:(
Hey,
Ok. So I was having starter problems,you know the 'single click' every now and then.So after searching,I decided to change the contacts and plunger.Did that,and it was running good for a while,starting every time. Then recently it started acting the same way. Got my battery checked,and it turned out bad,so I replaced that. CARS STILL ACTING UP.everytime it does that'one click,I can here like a low electric motor trying to turn.
checked the wires.replaced the positive terminal. Starts everytime I get a jump. It doesn't even need to charge,it will start as soon as you connect the jumper cables. Any help?
All the threads I searched through,seems like the contacts fixed their problem,but I did,and same problem.
Thanks in advance
Thanks in advance
Looking is one thing, but measuring the actual voltage at the solenoid terminal, while under load, will tell you what is going on. Easy enough to make up a little test pigtail (like below) and that will let you measure the actual voltage that the solenoid is seeing when you turn the key:
If you are getting much more than about 1/2 volt drop from the battery at the solenoid, start looking for the source of the drop. There are quite a few wires and connections between the battery and the starter:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
zombie_barbarossa
10-02-2015 10:54 PM
