Leaking rear differential
Old 03-28-2012, 04:00 PM
cap85's Avatar
Ok...so where is it leaking out of. Where the 3rd goes into the axle or where the driveshaft goes into the third. RTV wont work on the pinion. The old pinion seal can be pried out with a screw driver.
all i know is that that seal in the carrier is leaking...not sure what gear though? and was told that the carrier had to be removed and to replace the seal there
i am just learning as i go along...thank you everyone for their help!
Old 03-28-2012, 04:13 PM
cap85's Avatar
ive been reading alot and watching different videos...different tips with each one. how do i know which is best?
i only need to lift the rear end right? and take off rear tires? ive read and watched with both suggestions...
Old 03-28-2012, 04:18 PM
4Crawler's Avatar
Did you read the how-to page I posted above?
Wheels on ground, no lifting involved.
Old 03-28-2012, 04:23 PM
cap85's Avatar
yes, thanks for posting it...good pictures...i will refer back to it. my manual says i need to replace the companion flange nut....would any auto parts store have that or is it special order?same with the seal...i assume they would haev it in stock
Old 03-28-2012, 04:34 PM
  #25
4Crawler's Avatar
I got my seal from Toyota, never tried an auto parts store. Same on the nut, or you can re-use if you don't mess it up to bad removing it. Probably good to have a new one on hand just in case.
Old 03-28-2012, 05:44 PM
  #26
rattlewagon's Avatar
Depends on what seal your changing! Where is it leaking out of? Pictures are worth 1000 words.
There isnt a seal in the carrier, its either the pinion seal or the 3rd seal.
Old 03-29-2012, 06:13 AM
  #27
Utah4Runner86's Avatar
Seriously - you're getting multiple sets of advice here based on what folks think you're talking about, and it's probably confusing the heck out of you...
Do you understand what the 3rd member is? Are you leaking at the flange where the driveshaft meets the 3rd member or where the 3rd bolts up to the axle housing?
Old 03-29-2012, 07:37 AM
  #28
BMcEL's Avatar
This is one of those times when a few pictures would really help.
Old 03-29-2012, 07:49 AM
  #29
photoguy2354's Avatar
Location: Currently Virginia Beach, Va. Hopefully back to Wa. within the year...
I don't mean to but a couple shots of the center part of your rear axle from the sides, the bottom and the back can really simplify all the confusing advice you are getting. If you don't know how to upload them, PM me and I'll shoot you my email so you can send them to me and I'll upload them for you so you can get the info you need! At this point it's just a guessing game on what you should listen to and everyone else guessing what might be leaking.
us, you.
Old 03-29-2012, 12:41 PM
  #30
cap85's Avatar
i will get some pics up this weekend when i work on it....when i took it in..the mechanic showed me that the leak was coming from what looked like,to me, a gasket on the housing...i don't know all the terms YET but will! thanks everyone...tomorrow or saturday, i will have pics up.
Old 03-29-2012, 12:44 PM
  #31
cap85's Avatar
the quote the shop gave me specified that the differential carrier is to be removed and replaced and a new seal...so, it must be the pinion seal but that is inside so you couldn't see it right?
Old 03-29-2012, 12:48 PM
  #32
4Crawler's Avatar
If it is leaking around where the drive shaft attaches, then that is the pinion seal. My writeup covers that replacement.
I fit is leaking where the 3rd member (differential) bolts into the axle housing, then that is the seal around the housing. You might first try snugging up the nuts on the studs and see if any are loose. If that does not fix it, lift wheels, pull axle shafts out 4" or so on each side, pull 3rd member, clean and reseal the opening and re-install the 3rd. Re-install the axles and bleed the brakes.
Old 03-29-2012, 12:53 PM
  #33
cap85's Avatar
im sure i sound like such a rookie...well, i am! but i want to learn everything i can about his truck!
Old 03-29-2012, 01:08 PM
  #34
BMcEL's Avatar
The studs in the housing that hold the third member (differential/carrier) can sometimes begin to pull out which can also cause it to leak. This can be fixed by replacing the studs with bolts.
Pretty easy stuff, even for a rookie:
https://www.yotatech.com/forums/f116...cement-241933/
Old 03-29-2012, 01:09 PM
  #35
cap85's Avatar
i am going to go take some pics right now to post...
Old 03-29-2012, 01:25 PM
  #36
cap85's Avatar
its not letting me upload my pics...says it is too large....
Old 03-29-2012, 01:31 PM
  #37
BMcEL's Avatar
Upload them to a media hosting site like photobucket and copy/paste the IMG code here.
Old 03-29-2012, 01:36 PM
  #38
cap85's Avatar
k..i just made an account and put them on there..now what? my username is cap610
Old 03-29-2012, 01:46 PM
  #39
cap85's Avatar
i dont see an image code
Old 03-29-2012, 01:49 PM
  #40
cap85's Avatar
found it..my computer freezes and is slow...
Quick Reply: Leaking rear differential
