| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Largest Optima Battery That Can Fit?
#2 (permalink) |
There are only two sizes as far as physical size that I know of. You should go to the optima website, make a note of the LxWxH and then go and make a measurement of your tray and the space you have, also make sure the hood will close. Then you will know what you need to do from there.....be it a different holder or a bigger tray, or not being able to use the large batt.
I can't tell you for sure since I own a 1st gen. I'm not a big fan of systems, because they always end up being more trouble than good. and they make you're truck a target for theives. But if you do, I suggest search and read up on alternator upgrades and capacitors for your system in addition to the optima battery. You may find that you would like to run two batteries as well. Its all up to you.
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles |
#3 (permalink) |
Super Moderator-Sponsoring Member
Staff
You'll want a D34/78 IMO. Most Optimas will fit as most are 7"x10" and fit in the OEM tray easily.
The problem is that they are SHORT compared to a water non sealed battery so you'll need a spacer or a custom battery box/top bracket.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#4 (permalink) |
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| what is the largest tire I can fit? | Lifted96 | Newbie Tech Section | 31 | 02-15-2007 07:11 AM |
| Largest tires that will fit my stock 82? | futurerunner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-05-2005 08:06 AM |
| Optima Battery... | ilion | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-16-2004 12:12 AM |
| Optima battery | Mack | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 04-26-2003 08:22 AM |
