Ignition lock cylinder question
Old 12-15-2011, 02:59 AM
2003mikem's Avatar
I went to leave my house last night and my key would only turn a little bit.
I worked it a little bit and I now can turn it to the accessory.
My question is what are the chances it is the lock cylinder and not the column assembly?
Also my Hanes says I have to take the steering wheel off to change the lock cylinder is this correct ?
Any help would be great.
I have it park on the street and if it is there over night I will get a ticket.
1998 4runner
Old 12-15-2011, 04:54 AM
waskillywabbit's Avatar
It would be useful for all the questions you ask if you would put the vehicle you own in question in your sig.
Try some graphite.
:wabbit2:
Old 12-15-2011, 05:32 AM
toyotaPmanager's Avatar
try a new key cut from vin from the local dealership. sometimes it is nothing more than wear on the key. should cost less than ten dollars to have a new one cut by vin. cheap fix that works about 50% of the time
Old 12-15-2011, 05:35 AM
2003mikem's Avatar
I have 3 keys all 3 do the same. And one is a new cut key by vin from dealer.
Old 12-15-2011, 05:42 AM
then it is most likely you will have to replace key and tumbler set. i would try some powder graphite like wabbit said first. GL
Old 12-15-2011, 05:47 AM
2003mikem's Avatar
I will try later today.
Do I have to remove the steering wheel ?
It looks like I shouldn’t have to ?
But my Haynes says I need to remove it .
Old 12-15-2011, 05:53 AM
www.ncttora.com/fsm
No you don't have to remove the steering wheel.
:wabbit2:
Sleaker
08-26-2020 06:03 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
94whiterunner
07-12-2015 07:15 PM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Ignition lock cylinder question
