Ifs lift, cant align, tire rods to long ?
I installed a trailmaster 4 inch ifs lift,
The tire rods are adjusted all the way in and the drivers side is pointing toe out way way to far?
Has anyone had this problem before?
Thanks for any response in advance
i run into it on an 87.when i was working at tire kingdom.guy took truck home and replaced the tie rod ends and when he got his oil changed 2 weeks later he said it had worked out .give it a try .worst case is that u have new inner and outer rods
Thanks for your replies,
I ended up just cutting both the rods by a 1/4 inch, really cleaning out the rusted dirty sleeve,
I got it to align enough to be easily adjustable, thanks for your help
06-01-2021 01:51 PM
XtraCab
04-12-2020 05:25 AM
09-04-2015 09:27 AM
