| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How does this 87 turbo efi 4runner look?
#2 (permalink) |
these are great rigs, I want to put a turbo motor in my 92....what is he asking? before you buy be sure to have it inspected by a reputible shop
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's... 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#3 (permalink) |
Hes asking $4,000, but it needs rear brakes and will need front tires, so i will probably talk him down a bit. What are common problems on these and what should i look for other than the obvious rust, tranny slippage, previous accidents, etc.
#4 (permalink) |
I'd have the turbo checked out...They don't last forever, but it shouldn't be much of a problem. I think that's a reasonable price. It's been repainted, but thats a good thing as long as no rust was just covered over. That truck is very much like mine, I don't have the turbo, and I have a manual, and I had the stripes put back on the sides wehn Mine was painted. As long as the frame looks good, then I say you found a great truck to start with.
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles |
#5 (permalink) |
there really isn't a whole lot I know of that goes wrong with them. The trannys are fairly strong. If you do a search here on 22rte's you might find something i dont know about...
__________________
#6 (permalink) | |
Quote:
Also, @ 189K you are looking at a turbo rebuild soon (at least) if it hasn't been done already. Remember, forced induction, generally speaking, increases wear in nearly every component of the engine; especially underhood temps, which in turn cracks hoses, o-rings, etc. From the pics it looks pretty clean.
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#7 (permalink) |
Yea i was wondering about the turbo. Do the turbo'd 22re generally not last as long as non turbod ones. I need to get a truck that will last for a while without many major problems and am on a budget.
#8 (permalink) |
I just sold my 87 SR5 Turbo...
I bought it with 130k on it and #3 rod bearing wiped out and the piston smacking the head.(drove it home in 4Lo ) Then built a 22rte for it and swapped it in.They are fairly tough, minus a weak turbo casting that will eventually fail due to excess heat near the wastegate. The other problem they suffer from is the fact that they are not Intercooled. This poses a huge problem, even with the low boost that they create even in stock form(5-7psi). The heat soaks up in the exhaust side and cracks the casing between the impeller and the wastegate causing boost to be lost under accel. But, even with a cracked turbo, they will still go alright. infact, a friend of mine bought a rotted out turbo xcab with a 5spd that was only making 3-4psi and on the ride home was able to spin through first and part of second... I would just talk him down as much as possible and expect the worst case scenario, that you may have to put a turbo in it. LC Engineering makes some good stuff for boosting 22re's. I would also check the fluids to make sure it isn't swapping coolant and oil. Good luck!
__________________
Fabricator/Eater of Pizza |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 87 4Runner TURBO for sale unfortunately | SimpleMan | The Classifieds GraveYard | 9 | 02-11-2007 04:42 PM |
| '87 turbo 4runner drivetrain questions | Numbchux | 86-95 Trucks & 4Runners | 4 | 11-29-2006 11:35 AM |
| 87 turbo 4runner help | obex26 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-19-2005 05:50 PM |
| trd90toyota's '87 Turbo 4Runner | trd90toyota | 4Runners-1st gen | 1 | 05-05-2005 12:52 AM |
| What do do with my '87 Turbo 4Runner | Briareus | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 08-24-2002 06:33 PM |
