how can i flush out my wiper spray
Old 12-08-2007, 01:58 PM
85toy's Avatar
i was thinking about running some viniger through it but im not sure if that is a good idea. any help is appretieted.
Old 12-08-2007, 02:09 PM
toy_tek's Avatar
Why do you want to flush it out? Is it dirty? Vinegar won't hurt it but I don't understand a need for that. If the tank is dirty just take it out and clean it up with a pipe brush, dish detergent and warm water.
Old 12-08-2007, 02:42 PM
85toy's Avatar
it has calcium build up in the lines and the tips are corroded with build up.
Old 12-08-2007, 02:54 PM
fork's Avatar
mine has the same problem. i'm interested to find a cheap and easy way without having to replace everything. i need to get my beater legal soon and they aren't spraying.
Old 12-08-2007, 02:57 PM
infiltrator's Avatar
i still dont understand why you need to be able to have water squirting out... i never use it.
Old 12-08-2007, 03:04 PM
85toy's Avatar
1. i like to have everything workin good
2. i live on a gravel road about 8 miles of it so my windshield gets dirty pretty often because of the dust.
Old 12-08-2007, 03:14 PM
EWAYota's Avatar
If it has calcium build up, maybe run some diluted CLR (Think thats what is called, calcium, lime and rust?) cleaner through the system.
Old 12-08-2007, 03:23 PM
85toy's Avatar
thanks ill try that.
4Crawler's Avatar
Yep, CLR or LimeAway would do the trick. Probably best to pull the washer nozzles off the truck and soak them in some CLR or LA overnight, maybe sticking a pin into the nozzle to loosen up the crud.
Old 12-08-2007, 03:24 PM
Discipher's Avatar
i can go through a gallon of windshield fluid in a week. i depend on the washer fluid working durin the winter months
Old 12-08-2007, 03:36 PM
CJM
CJM's Avatar
Yep, diluted CLR then flush with alot of water..
Old 12-08-2007, 03:40 PM
Dublin's Avatar
Heck all I ever do is stick a pin in the nozzle to clear my out, hasn't failed me yet.
Old 12-17-2007, 08:23 PM
Mr.Dabadina's Avatar
Is CLR and lime away safe on paint?
Old 12-18-2007, 05:55 AM
4Crawler's Avatar
I've used it to remove rust spots on paint before w/o issues. As long as it is not left on too long and washed off very well, it should be OK. Just don't want to let it dry on there, as the liquid evaporates, the phosphoric acid probably gets more concentrated.
Old 12-19-2007, 10:42 AM
deserttoy84's Avatar
make sure to start at the source, Take the bottle off first and clean it out real good. I personally would just buy all new rubber line, It cost a couple bucks(prob cheaper then a bottle of CLR) and is fairly easy to replace. then clean the nozzle out real good, you can just let em sit in warm water or blow em out, whatever works.
Old 12-19-2007, 10:54 AM
isaac338's Avatar
on that note, can you aim those nozzles? mine spray all over the top of the windshield and i have to run the wipers periodically for 5 minutes after using them cause of the drips. they'd work way better if they hit the middle of the windshield.
Old 12-19-2007, 10:56 AM
clr and lime away are GODS! :]
Old 12-19-2007, 03:38 PM
Usually you can stick a needle in the sprayer and move it to adjust them. thats the way mine is at least
Old 12-19-2007, 07:08 PM
Dublin's Avatar
Using the needle trick to adjust them works well (it also clears the nozzles). Fast, easy and under a minute, JMO.
Old 12-20-2007, 06:13 PM
WCorbett's Avatar
Speaking of is there anyway to aim the rear squirter on a 4runner up so when someone tailgates me I can wash their windshield?
Quick Reply: how can i flush out my wiper spray
