Evolving into a REAL crawler
IMO mostly so you can have a normal 2.28 low range reverse. Instead of bein stuck in super slow reverse. Unlike forward were you can always use a taller gear.
And with duals one case can be 4.7 and the other one 2.28 for a super low almost 7 to 1 ratio.
Duals just give way more options. Sometimes 4.7 is to slow but 4hi is way to high. So the factory low range is nice to keep.
Edit: missed that bit about the 4.7 low being too low, that's understandable.
But you can have 3 different low range option whenever you need them. You can literally shift between 2.28, 4.7, and 6.??. Come on,,,, thats pretty cool. More gears then a semi.
Yes reverse does kinda suck, duals do give more options but I think cost wise 4.7 single case is the way to go if you don't plan on duals in the future, if I get into a situation where my 4.7 is too slow and 4hi is to fast, I can always shift up all the way to fifth gear without any bogging and plenty of speed.
#25
#28
Ya and no driveline mods. The single case with 4.7 is awesome for the price.
Be neato if you could have a lower first and reverse so you could use 4hi on some of those more open trails. But now I'm just being picky. Low is low.
#30
smilen724
13
11-08-2015 04:11 PM
scott90
10-04-2015 09:21 AM
myotherrideisayoshi
09-29-2015 05:41 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Toys4parts
09-26-2015 01:56 PM
