clunking noise from right hub
Old 07-19-2010, 08:56 AM
irab88's Avatar
my right front hub "clunks" when starting to move forward and sometimes when accelerating from 1st to 2nd (just after shifting). it only does this once, and is fine while driving and slowing down in gear. about two months ago, i broke off a lug nut stud (i got really angry at it and ate it!) and took it in to get replaced. the noise started about a month later. i haven't noticed it in 4wd, but i'll check again soon.
oh, and the search results that come up for me are for a constant grinding noise, not a one-time clunk
Old 07-20-2010, 09:30 AM
colsoncj's Avatar
I would guess either something is loose, or your spindle bushings are broke/need grease.
Old 07-20-2010, 07:07 PM
R4G1NG_BU11's Avatar
Check the nuts that are holding the wheel on. I broke off 5 the other day just because they weren't tightned properly. Mine made a clunking sound until i only had one left, then it made a loud tapping sound. It took 3 of the bolts with it so just check em, no harm there.
Old 07-21-2010, 10:59 PM
02Runner.phxaz's Avatar
try checking to see if the wheel is bet, it could be rubbing against the calibrator.
Old 07-22-2010, 05:32 AM
irab88's Avatar
and while i have the decompression stabilizer off, i can check the state of the catalytic inverter, too
"bent" and "caliper", perhaps? checked that, it's fine. thanks, though
G-off
12-29-2015 12:44 PM
Kreedy1
09-08-2015 06:33 PM
anniesball
09-07-2015 11:20 AM
AkitaDog
09-03-2015 09:01 PM
gillesdetrail
08-03-2015 04:43 PM
Quick Reply: clunking noise from right hub
