Check engine code 25,26,51. 89 22re pickup
Old 01-06-2014, 02:28 PM
TheEastBeaster's Avatar
hi i have a check engine light on my 89 toyota pickup 22-re. i put in the jumper wire and it gave me code 25,26 and code 51. what does all this mean? i looked up 25,26 and it said that the 25 is Air/fuel ratio LEAN
Code 26 Air/fuel ratio RICH. so i figured maybe an O2 sensor? but im puzzled on Code 51 it says the AC signal on; DL contact off (in tranny shifter with diagnostic connector jumped).. does this just mean i have it in diagnostic mode or is it another issue?
symptoms are bad gas mileage, and sometimes while pressing the gas the truck putts/bucks to the point where it shakes the whole cab. this only happens when hitting the throttle, and seems to be worse at higher speeds.
any help greatly appreciated
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dr. Evil
06-07-2002 09:19 AM
Quick Reply: Check engine code 25,26,51. 89 22re pickup
