burning oil, only off camber?
so the last coulple time i've gone wheelin i have been burning oil on the trail. it seems to only happen after being off camberfor a while and then leveling out or at the end of the trail.
i've been told something about walve seals and also that i might have bad rings. any help is appreciated im ok with mechanics but still learning
thanks
thanks
thanks
thanks
when i got my 1st gen p/u it smoked white and the guy i got it from told me the engine was recently rebuilt. i thought yah yah hes just pullin my leg but when i pulled the valve cover you could eat off of it, no joke lol. Come to find out they used crappy valve seals. luckily i was able to pull do it with out pulling the head. but if its blue smoke you need new rings.....
it looks white in the video. its from my friends phone so idk how to post it. i'll pull my valve cover off later when im working on it. it runs fine otherwise though and my pressure is fine. it has only done it on the trail which is what im confused most about.
thanks for the replies guys
got the video figured. hope it works.
<iframe width="425" height="349" src="http://www.youtube.com/embed/ufwirxb6rJc?hl=en&fs=1" frameborder="0" allowfullscreen></iframe>
looks like i'll be doing a compression test after work tomorrow. what would an ideal compression be?
its funny how new i am to this whenn most of my friends built they're rigs from the ground up
so. compression test results are as follows
#1-175psi
#2-160psi
#3-175psi
#4-175psi
i might have bumped the release valve on the second one. was gonna re-do it but it started raining. these results are also dry. didnt do a wet test yet.
#1-175psi
#2-160psi
#3-175psi
#4-175psi
My old 4runner did the same thing last time I took it out. I have since sold the truck but kept the engine for a new project.
Keep us posted on what you find out.
its for sure comin out the exhaust pipe. first time it happened it filled the whole cab with smoke cause my windows were all down and scared me pretty good.
Blamalam
03-12-2022 07:34 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
TJWilly
07-31-2015 02:05 PM
HookahRoo
07-20-2015 07:06 PM
rushw
07-18-2015 01:46 PM
