Build
Old 03-14-2009, 04:57 PM
MASTA SHAKE's Avatar
Build
I have a 1988 Toyota Pickup. The 22RE was taken out buy the guy i got the truck from and he gave me a 22R to put in it. I have several questions.
22RE uses an electronic fuel pump so since i put in a 22r with a mechanical fuel pump that is located on the block would i have to take out the fuel pump in the tank?
We also tried starting it today but it just turned over and would not start (yes we put gas in the carb). would it have to do with the timing, carb, or anything else?
This is the first truck Ive ever had especially put together any help would be greatly appreciated https://www.yotatech.com/forums/imag...s/headbang.gif
Old 03-14-2009, 06:29 PM
FredTJ's Avatar
I would think that you'll have to remove the pump in the tank.
More important than that however, I would think, is that the swap is illegal as he$$ ......
Fred
Old 03-14-2009, 07:45 PM
i have another tank from an 86 that might work
Old 03-14-2009, 08:33 PM
TOYOTA 1's Avatar
no, keep the efi tank! the manual pump will pull threw the efi pump just fine.
whats the timing set at?
you getting spark out of your distributor?
Old 03-15-2009, 06:35 AM
b/s rules's Avatar
yeah, keep your tank, unplug the elec.pump and it will work fine.
Old 03-15-2009, 11:16 AM
ok thanks i dont know what the timing is set at. how do you check what the timing is set at? Plus another fuel question on the tank that is on the truck it has two fuel lines coming out but on the other truck it has three and how would i hook that up?
kawazx636
10-06-2021 03:03 PM
LittleUgly
15
01-02-2020 01:30 PM
smilen724
13
11-08-2015 04:11 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Build
