Brake line fittings, adapting to aftermarket Prop valve.
Old 05-27-2012, 05:29 AM
SuperStoner0127's Avatar
Question Brake line fittings, adapting to aftermarket Prop valve.
I have an 87 4runner mostly stock..since purchasing 4 years ago I have used as a daily driver and extreme off road machine. Throught the years I have had countless brake issues, so today I rebuild the entire brake system removing lspv putting on an aftermarket prop valve from Jegs with one inlet and one outlet. I have removed the brake line going from front to lspv, and blocked appropriately. however the aftermarket LSPV from Jegs has different fittings and I am unable to screw the current brake line into it (which i believe is M10x.1?) It seems the fittings on the prop valve are female Npt? Not exactly sure with all this fancy brake line adapter lingo, basically what I'm looking for is what adapters do I need to purchase to attach my current brake lines to these after market fittings.
I will be attempting to add photos momentarily.
Old 05-27-2012, 05:49 AM
I will also be adding a used booster and master cyl because I believe they may be contributing to the over all problem of fluctuations in the rpm when brake is applied
Old 05-27-2012, 05:59 AM
waskillywabbit's Avatar
Your MPV probably has standard fittings, your Toyota metric. You can get adapters at Summit or JEGS.
:wabbit2:
Old 05-27-2012, 06:14 AM
I am trying to connect the "brake line" on the bottom left to the "inlet" on the bottom right. Above the two I included a view inside the "inlet" I am trying to connect to. Not sure what adapter I am suppose to use any help provided would be greatly appreciated.
Attached Thumbnails Brake line fittings, adapting to aftermarket Prop valve.-brakeline.jpg
Old 05-27-2012, 06:36 AM
Perhaps this is the adapter i am looking for?
Adapter, Master Cylinder to Brake Line, 3/16 Tube to 3/8 in.- 24 Flare Female, -3 AN Male, Each
http://www.summitracing.com/parts/WI...n/?prefilter=1
Old 05-27-2012, 06:52 AM
Your Toyota fittings are metric. You need standard to metric brake line fitting adapters.
:wabbit2:
Old 05-27-2012, 07:22 AM
thanks wabbit for the quick response as always. i understand i need standard to metric brake line fitting adapters, im just not sure how or where to find them with the -3an, -4an, 10mm x 1.25mm, NPT none of that makes sense to me. is the -3an standard?
Old 05-27-2012, 09:09 AM
Everything you want to know about brakes and more is here:
http://www.pirate4x4.com/forum/showthread.php?t=775780
:wabbit2:
Old 05-27-2012, 11:27 AM
wyoming9's Avatar
Wink
Some place on your new valve it should tell you what size the female connections are . Maybe on the package ?? maybe the website you ordered it from.
you just need a adapter with a male thread that size and a Toyota M10x1 female thread .
Old 05-28-2012, 05:16 PM
after further research I discovered a prop valve is not exactly required... I removed the valve all together plugged the front to back line and connected the back line directly to the flexible line that goes to the axle, after some bleeding TLC I have a hard brake pedal that stops my vehicle in an orderly fashion.
Old 05-28-2012, 06:23 PM
strykersd's Avatar
That would work on a trail rig but could be deadly on a DD. Without a proportioning valve in the rain or ice, your back brakes will lock up before your front brakes.
Old 05-29-2012, 11:08 PM
wyoming9's Avatar
Wink
One just needs to learn how to brake these valves were never on the early pick ups when I learned to drive.
Just engage Common sense before the transmission.
Old 06-01-2012, 05:57 AM
muddluvr's Avatar
The fittings to adapt the wilwood brake valve (which has 1/8 NPT ports) to the 10mm x 1.0 brake line fitting are
361-916103 ST-3 female to 1/8 NPT
361-989538 -03 AN to 10mm x 1.0
you will need two of each
these part numbers are from jegs but if you leave off the "316" you should be able to do a search on just "Earls" part number.
I was going to use these to add rear disks and bigger front brakes to my 87 4runner, but i found it easier to cut and reflare the brake tube with standard brake fittings..
kazuya2416
04-05-2024 02:17 AM
09-04-2015 09:27 AM
87turboPA
07-12-2015 07:49 AM
crashburnoveride
07-10-2015 06:39 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake line fittings, adapting to aftermarket Prop valve.
