Battery Wont Hold Charge- 92 4runner
Old 08-09-2010, 11:27 AM
Brittany_ann0463's Avatar
I have a 92 4runner- recently installed engine that wont hold a charge on the battery (Which is brand new) On the dash when it starts there are a few lights on while it is running......
Rear anti lock Light On
Battery Light On
O/D Off Light On
A/T oil Temp Light On
What do I need to do to make the charging system work? Any suggestions would really help! Thanks Everyone!
Brittany
Old 08-09-2010, 11:39 AM
totally a bro
Staff
vital22re's Avatar
Hows the alternater? is it putting out 14v ? Is the alternator hooked up? What motor? v6 or 4cyl?
Old 08-09-2010, 11:41 AM
waskillywabbit's Avatar
Did everything work before the engine swap? If so, you obviously didn't get something hooked up back up right. Did you pay to have the engine installed? If so, make them fix it.
Otherwise get a FSM www.ncttora.com/fsm and start troubleshooting.
Old 08-09-2010, 11:48 AM
Engine is a V6.... not sure if it held battery charge before the engine swap. We bought the truck with a hole in the block but we had a engine to put in it in which my dad put in just last week... all fuses have been checked it just wont hold the charge!
Old 08-09-2010, 12:08 PM
totally a bro
Staff
vital22re's Avatar
Need to check the alternator to make sure its giving a charge.
Old 08-09-2010, 02:56 PM
wyoming9's Avatar
Red face
with the engine running take a multimeter and read across the positive and negative posts of the battery.
Tell us what it reads .
We will go from there.
Good luck
Old 08-09-2010, 03:47 PM
1990yota-pickup's Avatar
do you have a remote amp, or a jerry rigged cb, radio system... those are usually the main problems with stuff like that..
do you have your main wires hooked up correctly
is the alternator hook up clip broke, burnt or just not making a good contact
A2theK
07-12-2015 10:46 AM
Kalihi,HI
07-09-2015 04:29 PM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Battery Wont Hold Charge- 92 4runner
